Clutch "pop" half-way through pedal press
Old Aug 22, 2010 | 07:33 AM
Brother_Bluto's Avatar
Brother_Bluto
With the hot days of summer, I've noticed that my MCCS chutch has a "pop" to it about half way through the pedal press. I always press to the floor, never half-way... but there is definately a release, or pop that happens about half-way through. I only notice on very hot days 90deg+ and is usually gone after driving for a while. Should I be concered? It is a 2009 MCCS with about 24K on it.
Old Aug 22, 2010 | 07:40 AM
ScottRiqui's Avatar
ScottRiqui
My '06 does this as well, but I notice it most on the "upstroke" - when I have the pedal pressed all the way to the floor and raise it slowly, there's a little "catch" partway up that I can feel in my foot.
75k miles and no problems, so I'm not too worried about it, but I thought it was strange as well.
Old Aug 22, 2010 | 08:38 AM
DrewN's Avatar
DrewN
Is it an audible pop, or is it a hitch in the pedal travel? If it's a hitch, I had something similar and had the whole clutch pedal assembly replaced under warranty. Apparently the clutch pedal was deformed and hitting the slave cylinder halfway down its travel.
Old Aug 22, 2010 | 09:38 AM
onefish2's Avatar
onefish2
I recently had the same thing. My car was rear ended and sat for some time while being repaired. I noticed this "hitch", or "pop" when I stepped on the clutch. It was audible as well. I noticed this as soon as the car was returned to me and I drove away from the dealer. The dealer said that its because it sat. Let the fluids circulate. Let's see what happens in 500 miles. I said BS. So I took it back again and on the 3rd try they said they adjusted the position of the pedal.
I do not know what that means exactly but they fixed it on the 3rd try.
Old Aug 22, 2010 | 01:44 PM
009Mini's Avatar
009Mini
Mine is going in this week for the clutch pedal "pop", which sounds like a spring snapping on both the up and down stroke. It is also going in for the "cold start rattle" which has happened a couple of times recently, and the 2nd oil change/full service. I hope they get it all taken care of in one trip, but I doubt it. I have never had such a lack of confidence in a service dept.
My car has been very dependable and it is fun, but it seems a lot of the MINI dealerships really let us down when it comes to good service and fixing "known" problems.
Old Aug 24, 2010 | 07:20 PM
jarez mifkin's Avatar
jarez mifkin
I had same issue on my 09 JCW. The clutch pedal pop was fixed on the first trip. Death rattle took a second trip to fix it. They did the tensioner update on the second visit. But now I've got a low to no boost situation happening. I opened the hood when I got home and noticed that the air box was very loose. Going back tomorrow morning...
Old Aug 25, 2010 | 12:35 PM
flintdragon's Avatar
flintdragon
Had the same problem but the dealer thought it was user error in that I was pushing the clutch at an odd angle. I'm 100% certain that is not the case. There so little room down there for any kind of angle. lol... Regardless, they replaced it free of charge and the pedal feels great once again.
Old Aug 25, 2010 | 09:41 PM
kunishi's Avatar
kunishi
I had a similar "pop" issue, but during the release of the clutch. My car was just 3 months old when the problem surfaced. Took the car to my dealer, they examined the pedal assembly and noticed a small broken part (I never did ask what was broken) they replaced the part (maybe a nut or washer) did some adjustments -- pop was gone. It's been a year and the "pop" has not resurfaced. I guess the thing to note is that something broke in the assembly. I also noticed that when the "pop" surfaced, the clutch had a *tad* more sideways play. I hope this helps.....
Old Aug 26, 2010 | 04:24 PM
Brother_Bluto
it is definately audible and can feel it with the foot. It's going into the shop next week. Few other issues to take care of as well. :-)
Old Aug 27, 2010 | 04:27 PM
mini-mal's Avatar
mini-mal
I just noticed that my 2005 MCS does this as well. Let us know what it turns out to be, and what the solution is; if it is something that can be fixed rather easily, or if a trip to the dealer is warranted.
Old Jun 26, 2015 | 08:54 AM
RHcoopers's Avatar
RHcoopers
Has anyone found resolution to this? I have the same situation after having a mechanic install a Valeo single mass clutch kit. The feeling goes away after the car is turn off, will stay smooth after a few uses from start up but once i've driven around town the pop in and out starts to happen. Thinking it may be a fluid based issue. I do have light seepage from the slave cyl if I pull the boot back, so maybe air bubble? But the popping is starting to feel mechanical and I hear the clutch clap. ughh.
Old Jun 27, 2015 | 12:27 PM
robynlori's Avatar
robynlori
I just paid $489 to have my clutch pedal bushings replaced. The clutch replacement was covered by my extended pre-paid maintenance plan, but the bushings were not covered by either the pre-paid maintenance or the my extended warranty.
Old Jun 27, 2015 | 04:13 PM
Systemlord's Avatar
Systemlord
I had to do it myself, it was cheap because the labor was on me, parts were cheap (ECS Tunning). I bought a new pedal and both bushings, the hardest part is getting the return spring back on, not easy! I spent too much time upside down.
Old Jul 1, 2015 | 02:29 PM
BlairsJCW's Avatar
BlairsJCW
Did we ever find a solution to this pop ?
I purchased a used 09 JCW 90k miles..
Ive put about 1,000 miles on the car, recently it has been very hot ( 100F+ )- I have just started experiencing this "pop". I would describe it as a change in pressure on the clutch that i can feel in my foot, it also lets of some sort of noise ( sounds like compressing air ). Happens when the car is on and off.
This is a clutch pedal issue - ( havent had any signs of a slipping/failing clutch ) -- Just this extremely annoying tick/pop everytime i push down on the clutch pedal.
Old Jul 10, 2015 | 07:01 AM
Think it was just the pedal and new bushings:
http://www.ecstuning.com/Search/SiteSearch/35316772406/
35211158290 Bush Bearing - Priced Each
http://www.ecstuning.com/Search/SiteSearch/35211158290/ES2675029/ x 2
Old Jul 10, 2015 | 09:21 AM
BlairsJCW's Avatar
BlairsJCW
Awesome, thanks for the reply. I will give this a try. Having not looked into it yet, is this a at home job, or something to take to the shop.. and if so anyone know what it cost if they have had it done before ?
Can i order those directly from your site, 2009 JCW
Old Jul 10, 2015 | 09:23 AM
Yes,
Add to cart and check out. If you are mechanical , you could do it at home. Otherwise , get a quote for a local shop.
Old Jul 10, 2015 | 09:28 AM
BlairsJCW's Avatar
BlairsJCW
Great, thanks again. Ill post a reply with what it costs for install and if it took care of the problem or not.
Old Jul 25, 2016 | 11:36 PM
RHcoopers's Avatar
RHcoopers
So did it work?
Old Jul 26, 2016 | 12:33 PM
Purpleoctopus's Avatar
Purpleoctopus
I am curious to hear if it worked as well. Mine has done this for years now.
Filmy
Jun 28, 2016 08:58 AM
thadscottmoore
Sep 25, 2015 10:07 AM
Sep 16, 2015 06:22 AM
wildwestrider
Sep 4, 2015 06:25 AM
Sep 3, 2015 02:06 PM
