Shifter Cable Broke.....I Think. Please advise
Old Nov 16, 2015 | 09:24 AM
  #51
tragedybysyntax's Avatar
tragedybysyntax
I crawled under for a photo but can't find a model # or anything
Old Nov 16, 2015 | 09:57 AM
  #52
Looks like condition "A" gear shift lug, its that nylon / yellow color.
25117518850
https://www.ecstuning.com/Search/SiteSearch/25117518850/
Old Nov 16, 2015 | 11:17 AM
  #53
tragedybysyntax
looks like it! how do I figure out the cable needed for the type "a"? it's the left (drivers side) I need
Old Nov 16, 2015 | 12:03 PM
  #54
Whats the last 7 digit of your Vin again, then you can go to realoem.com , copy / paste , then go to the gearshift section > gearshift manual transmission > select the diagram that shows condition A and condition B shift lug.
Then look at the picture of Condition "A" , look below at the parts #6 is the driver side, look for condition A , if no condition for that year/ model , then the part description does not say anything.
Whats the last 7 digits of your VIN, i can help you.
Old Nov 16, 2015 | 12:15 PM
  #55
tragedybysyntax
WMWRE33473TD58188 I believe that is the VIN. ��
Old Nov 16, 2015 | 12:19 PM
  #56
Yep that driver side ( left ) is the 708 version. Which is on BO
https://www.ecstuning.com/Search/SiteSearch/25117531708/
The 707 version you have is for the passenger side ( right ).
25117531707
Old Nov 16, 2015 | 12:20 PM
  #57
tragedybysyntax
is what it looks like.... if my eyes serve me correctly?
Old Nov 16, 2015 | 12:22 PM
  #58
tragedybysyntax
so I wonder how I'm going to get the cup over the ball on the bulkhead on the car. guess the hole on the original one was just blown out of shape. still seems impossible to get that sucker on there
Old Nov 16, 2015 | 12:31 PM
  #59
They fit tight just make sure the 25117531708 part goes on the Left side ( driver ) and 25117531707 goes on that right side ( passenger ) . They snap on when new pretty tight. They have a little grease pre greased in the socket on the new ones.
Old Nov 18, 2015 | 03:54 PM
  #60
tragedybysyntax
the ball on the right is clearly bigger tho, what's where I'm at a loss.
Old Nov 18, 2015 | 08:06 PM
  #61
kaneguy's Avatar
kaneguy
It looks like the pass/driver shifter are designed to be unique so to ensure proper installation. The driver side ball was probably designed larger for that purpose.
Old Nov 18, 2015 | 09:18 PM
  #62
tragedybysyntax
if that's the case then are the cups on the 707/708 different sizes to reflect that?
Old Nov 19, 2015 | 10:35 AM
  #63
tragedybysyntax
ecs, does this sound right to you? or did some idiot put a bigger ball on my transmission and not tell me? lol
Old Nov 19, 2015 | 10:41 AM
  #64
That looks right , one side is bigger then the other and the cables sets correspond to that, so you dont mix the cables up, did mine of on the 05 MCC and it was the same way. they fit tight and snap on pretty hard/.
Old Nov 22, 2015 | 08:38 AM
  #65
tragedybysyntax
Well I'm screwed... trying to pry on the new cable and it's stuck halfway and cracked the holder. *tosses a wrench* lol, and I thought I was getting an alignment today, bahahaha
Old Nov 22, 2015 | 08:57 AM
  #66
tragedybysyntax
well I backed it out and tried again, it's mostly seated so I'm rolling with it.... for my next question, what trick am I missing here to get the new cable on the ball?
Old Nov 23, 2015 | 09:08 AM
  #67
tragedybysyntax
Old Nov 23, 2015 | 09:23 AM
  #68
tragedybysyntax
annnnybody?
Old Nov 24, 2015 | 05:55 AM
  #69
Ouch, sorry you had that happen. Try tapping it on, on the top, and press stright down. Its snaps on tight. When i did mine it was very tight so it will not pop off.
Old Nov 24, 2015 | 06:19 AM
  #70
tragedybysyntax
okay...
now In the foreground you can see that the air box tray is in the way of making my life easy... you guys somehow get that out or just work down in the hole? haha
Old Nov 24, 2015 | 06:22 AM
  #71
I took mine out. But with some contorting of your hands you might be able to reach down and push it on. But at the risk of beating up your hand , weary tight fitting work gloves if you do.
Old Nov 24, 2015 | 01:52 PM
  #72
tragedybysyntax
I have pretty big hands... I say we take it out! I just need to figure out how, haha
Old Nov 25, 2015 | 08:35 AM
  #73
nkfry's Avatar
nkfry
Just use a prybar to pop it on, pry against the fiberglass/plastic tray and the cable should pop on.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Nov 25, 2015 | 09:18 AM
  #74
tragedybysyntax
yeah I tried that... won't pop on. I still don't think this is the right cable honestly. Doesn't even slide down on the plastic piece that holds it level. Pretty frustrated at this point, might just get it towed to my local shop to take care of it
Old Nov 25, 2015 | 09:21 AM
  #75
nkfry's Avatar
nkfry
Without looking at it personally, it may be the wrong cable. They shouldn't require the power of Thor to install, just a bit of pressure and they should pop on.
Phone:586-792-6464
