Broken Sunroof
Old Jul 1, 2010 | 07:22 PM
hardiek's Avatar
hardiek
Broken Sunroof
Does anyone know where I can get details on how the sunroof linkage is supposed to work so I can repair mine? The sunroof on my 2003 mini cooper s opens perfectly fine. But when closing it stops about 1/2 way and reverses back to open. I have to hit the switch a bunch of times while pushing the glass up slightly to get it closed as it won't do it by itself. Any idea what part needs replacing?
thanks.
Kevin
Old Jul 2, 2010 | 06:01 PM
zminitech's Avatar
zminitech
It may be the motor. Try lubricating the tracks, unfortunately there aren't really any separate parts for the sunroof other than the complete assembly. If lubricating doesn't fix it, try removing the front glass panel, there should be a few screws on the inside panel on each side.
If the problem continues with the glass removed, then you may need a new sunroof. Also try initializing it by holding down the sunroof button for 15-30 seconds in the close position.
Old Jul 10, 2010 | 02:43 PM
DaveVT02S's Avatar
DaveVT02S
Does it stop (and reverse) in the same exact position every time? (Check for a burr or debris in the track) Or does it happen at various points, or possibly not every time? (Lube the tracks)
ian260
Mar 29, 2017 06:08 AM
Fordgt4
Oct 10, 2015 10:42 AM
Jim Ferrell
Oct 6, 2015 08:09 AM
B1mm3r101
Oct 1, 2015 06:22 AM
daviday
Sep 25, 2015 01:31 AM
