car flickers on and off after key is out!?
Old May 15, 2010 | 11:51 AM
rhcp4life's Avatar
rhcp4life
i parked my car went to bed and when i woke my car was dead with the no keys in it
the power was on as if i had the key in and turned but no key
the power flickers on and off and will kill my battery if i dont disconnect it
im thinking maybe it my ignition but im unsure
any ideas?
Old May 15, 2010 | 01:35 PM
HRM's Avatar
HRM
Sometimes hanging a big huge jumbo keyring from the ignition causes them to get quirky like this, though I suppose it can happen to tiny key rings too, but not as common.
You may need a new ignition if you can't find a way to reliably remove the keys and be assured the ignition is indeed off.
Old May 15, 2010 | 04:42 PM
rhcp4life's Avatar
rhcp4life
the key comes out fine, but it flickers on and off with no key and i dont even have a key ring just the key is all i use...
Old May 16, 2010 | 10:13 PM
rhcp4life's Avatar
rhcp4life
bump......
Old May 16, 2010 | 11:04 PM
rkw's Avatar
rkw
Describe the symptoms in more detail. What flickers on and off? The dash or interior lights? If the dash, do the instruments seem to be turning on (any numbers such as the odometer displayed) or just the backlighting? By flickering, do you mean brief flashes, or longer intervals?
Old May 17, 2010 | 06:23 AM
erickvonzipper's Avatar
erickvonzipper
The body control module controls things like the interior and dash lights. If those are affected, you might wanna have it checked via the OBD-II port.
Old May 17, 2010 | 08:17 AM
rhcp4life's Avatar
rhcp4life
the the odometer with numbers.. all of the lights that come on when you turn the key, are turn on
they flash off and on for a while then stay on then shut off then stay on, its totally random
Old May 17, 2010 | 11:17 PM
rkw's Avatar
rkw
As far as I could tell from wiring diagrams, power needs to go through the ignition switch for the instruments to turn on. The ignition switch feeds power to the instrument module through fuses F40 and F9. If you pull those fuses and the problems stop, there's a chance the ignition switch is at fault. The instrument module is also supplied power by F21 (unswitched, always hot) and the immobilizer on F5. If pulling F40 and F9 doesn't stop the flickering, the instrument module itself might have gone bad. The instrument module is inside the center speedo and repair would involve replacing the entire speedo.
Old May 18, 2010 | 09:31 AM
rhcp4life's Avatar
rhcp4life
so i just noticed the whole carpet is soaking wet know idea why
im going to remove the carpet and dry it out
Old May 18, 2010 | 10:05 AM
rkw's Avatar
rkw
You'll have to dry out more than just the wet carpet (which by itself wouldn't have caused the problem). The water probably went down the sides of the car and got into electronics or connectors behind the footwell panels.
Old May 18, 2010 | 01:02 PM
rhcp4life's Avatar
rhcp4life
yeah i have removed the carpet sucked up all the water with a shop vac then let the car sit and air dry out
no problems as of now
09R56
Nov 16, 2022 10:49 AM
TunedGP
Oct 1, 2015 04:18 PM
ludedude
Aug 10, 2015 07:16 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
