Noise when turning A/C on?
Old Oct 20, 2014 | 02:34 PM
  #126
fonso86's Avatar
fonso86
Originally Posted by cccplus
There's an TSB install procedure pdf SIM640110 that you can find at the link below
https://www.northamericanmotoring.co...-database.html
Got it! thank you
Old Jul 28, 2015 | 09:39 AM
  #127
eliseo1981's Avatar
eliseo1981
I have a mini cooper 2009 S hatchback with the same humming noise. Called Mini and mentioned the bulletin number and they told me the following
Its a Damper Part with screws: Part number: 64509231714
part cost: 227.75
part with labor: 284.93
seems a little steep to me, found the same part for $120 online but no screws and I have no idea how to install it.
Old Jul 29, 2015 | 04:15 PM
  #128
automan21's Avatar
automan21
Where did you find the part for sale?
Old Jul 30, 2015 | 12:06 PM
  #129
eliseo1981's Avatar
eliseo1981
http://www.ecstuning.com/Search/Site...714/ES2673360/
Not sure if it has the screws however.
Old Jul 30, 2015 | 01:10 PM
  #130
Just talked about it here: 64509231714
https://www.northamericanmotoring.co...ml#post4108203
Old Aug 20, 2015 | 11:57 AM
  #131
eliseo1981's Avatar
eliseo1981
Well so long for them fixing a bulletin item for free (perhaps this was common knowledge to you guys) but if you are no longer under warranty no bulletin items apply free of charge and become the cost of the owner.
email received from mini----
Hello MINIac,
So I was relayed a message to reach out to you about a question on coverage for a bulletin.. Once the vehicle is out of manufacturer warranty then we are unable to do the bulletins at no charge.. they would then become customer pay items.
MINI Service Advisor
Advantage BMW MINI of Clear Lake
Old Aug 25, 2015 | 08:02 PM
  #132
Systemlord's Avatar
Systemlord
Is it at all possible to hear this humming noise when the AC isn't on? I hear a harmonic hum sometimes when I start my car up in the morning, the noise doesn't stay for long. For all I know it could be a friction wheel bearing going bad?
Old Aug 25, 2015 | 09:03 PM
  #133
eliseo1981's Avatar
eliseo1981
I guess its possible to hear it when the compressor is off but doubt it. It seems the vibration of the compressor is what causes the noise. Perhaps its the timing chain thing everyone else is complaining about. I am getting the timing chain tensioner (new version) in addition to trying to fix this compressor thing.
I tried using tie wraps to hold the compressor line down to prevent it from vibrating and it made things worse (so at least I know this is the culprit) perhaps I need to tie the tie wraps in a different direction. I just think buying a $100+ counter weight is way over priced.
Here are pictures of what I did and caused things to go louder, I think I need to use tie wraps to push the line down vs towards the wheel.
Attached Thumbnails Noise when turning A/C on?-wp_20150822_001.jpg   Noise when turning A/C on?-wp_20150822_002.jpg
Old Aug 28, 2015 | 10:13 PM
  #134
googlemini's Avatar
googlemini
Has anyone installed this themselves? My 2011 MCS makes the same noise. Easy to install without removing anything? Thanks
Old Aug 31, 2015 | 06:17 AM
  #135
The TSB is linked here which is linked through a couple threads.
Old Aug 19, 2016 | 08:34 PM
  #136
cargusjoh's Avatar
cargusjoh
I have possibly this sound also on a October 2010 build (with in the TSB range). This is the sound I have, is it the same for the TSB?
TURN VOLUME WAY UP
Thanks!
Old Sep 15, 2016 | 09:36 PM
  #137
cargusjoh's Avatar
cargusjoh
The dealer installed the weight/dampener per the TSB and the problem is solved.
Old Sep 16, 2016 | 10:49 AM
  #138
Yep, its right above. Glad its fixed.
Old Jun 24, 2017 | 11:28 AM
  #139
Captain_Slow's Avatar
Captain_Slow
Hi.
So, I've got a 2012 MCS that's making the exact same noise. I checked underneath it today to see if Mini actually decided to put the weight/damper on the solve the problem. Lo and behold . . .
Noise when turning A/C on?-q7fov5u.jpg
That sure looks like a weight/damper to me. Which now begs the question, why is it still making the noise? I didn't notice the noise last summer. I checked the fitment and it still seems quite snug on there. Any ideas?
Thanks!
doug5g
12
Apr 17, 2019 12:44 PM
cub4bearindiana
Jun 30, 2016 06:11 AM
maestro39
Oct 27, 2015 02:38 PM
patrioticmini
Aug 20, 2015 10:54 AM
damncajun
Aug 17, 2015 08:25 PM
