clutch problem
Old Feb 2, 2010 | 11:09 AM
theradiantmini's Avatar
theradiantmini
clutch problem
so my clutch is starting to slip on my 04 cooper s (usually when gettin on it around 4kRPMS) My buddy is gonna do the labor. My car is lightly modded (super charge pulley swap, intake, and rear sway bars) What brand do you guys recommend? I have heard you have to replace the flywheel as well. I also heard aftermarket flywheels cause problems and go out really fast. I was thinking about a stage 1 kit. Any ideas would be greatly appreciated. Also, is there any other maintenance that should be done while the car is in pieces? haha
thanks!
Old Feb 2, 2010 | 11:24 AM
MNCRYSS's Avatar
MNCRYSS
Depending on your mileage probably think about engine/transmission mounts upgrading to powerflex. And maybe a short shift kit while everythings apart anyway. Regarding clutches, seems like everyone here has had good luck with Clutch Masters products. OS Giken is relatively new so not a lot of feedback yet on them.
Old Feb 2, 2010 | 12:12 PM
theradiantmini
i have 67k miles on it. I heard to replace the super charger oil with GM supercharger oil and make a gasket seal for supercharger
Old Feb 3, 2010 | 08:02 AM
theradiantmini
anyone? bump..
Old Feb 3, 2010 | 03:25 PM
herbie hind's Avatar
herbie hind
valeo is said to be good for stock or there about . i would look at the fly wheel before dropping money on one . if no heat marks or scoring ; i would scuff it and run it . if you scored it then yup new one . just deglaze it . spec is said to be not good . it's tough but try to keep the dsc on to save on tires and clutches .
Old Feb 3, 2010 | 06:45 PM
theradiantmini
I know valeo sells just a clutch kit as well as a clutch + flywheel combo. I've never seen just the valeo flywheel on sale by itself. I know you cant resurface mini flywheels. I've always been told when the clutch starts slipping you should just replace both the clutch and flywheel. Any suggestions?
eliseo1981
Jan 28, 2021 02:45 PM
Zettinger
Aug 25, 2015 04:04 PM
Camaro108
Aug 25, 2015 02:44 PM
cornfly888
Aug 24, 2015 09:57 AM
Colt45Magnus
Aug 12, 2015 06:43 AM
