2006 MCSC Leaking Oil Pan Gasket
Old Jan 24, 2010 | 08:21 AM
MINI28741's Avatar
MINI28741
When I had the CAI and 15% pulley installed in my 2006 MCS Cabrio the mechanic showed me that the oil pan gasket had a small leak, at 16,500 miles. "Small leaks do not get smaller, only larger." The car is still under warranty so I called the MINI dealer in Charleston, SC. I was told that was a four hour job!!! Does that sound reasonable to y'all.
Old Jan 24, 2010 | 01:44 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
This is a chronic problem for MINI's and it's in a bad spot. Other parts need to be removed to get it off so it takes "them" 4 book hours. A good MINI Mechanic can do it in half the time.
Mine was replace this past summer along with the main bearing seal. What I should have done was to replace the old oil pan with a newer baffled style oil pan......maybe next time.
Old Jan 24, 2010 | 02:43 PM
MINI28741's Avatar
MINI28741
I am not aware of the "baffled style oil pan". Could you please give a few more details about it. Why is it an improvement?
Old Jan 24, 2010 | 03:45 PM
Some Guy's Avatar
Some Guy
A baffled oil pan has little walls in it that help prevent all the oil from going to one side of the oil pan or another, helping to reduce the chance of your car not getting oil in a hard turn. My opinion of this is that is the type of thing only track junkies really need.
Old Jan 24, 2010 | 04:55 PM
Capt_bj's Avatar
Capt_bj
I'm cornfused .... u r upset you might have to leave the car for 4 hours for the warranty service?
Old Jan 24, 2010 | 05:58 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Here is our baffled oil pan.
http://www.waymotorworks.com/wmw-baf...n-r50-r53.html
Even if they are doing under warranty, they shouldn't have a problem putting on the different pan.
Etrain
16
Aug 5, 2024 04:37 AM
ShadyCoop
Aug 24, 2015 06:05 AM
Etrain
11
Aug 20, 2015 10:22 AM
Aug 19, 2015 12:51 PM
Aug 19, 2015 08:28 AM
