starting problem
Old Dec 23, 2009 | 10:55 AM
josh_r53's Avatar
josh_r53
starting problem
right i'll start from the beginning, i front ended my mini the other month and i've slowly been replacing all the parts, radiator, bumper, engine mount, bonnet,
today i finally got everything together, the petrol gauge said it was empty so i filled it with petrol from a can, went to start the engine, ran fine for 5 minutes then died and turned off, tried to start it, started then immediately cut off.
went out 10 minutes later and the same thing happened again, ran for 5 minutes then turned off, then cutoff immediately after starting.
there's no petrol on the ground and the gauge says there's 5 miles in the tank,
i'm pretty gutted because it looks all sorted and wanted a wee drive
any input welcome, thanks
Old Dec 23, 2009 | 11:48 AM
wdietz186's Avatar
wdietz186
It sounds as if it needs more fuel to stay running.What is likely happening is the pump is sucking air after it fills the return lines,filter,etc. Put more fuel in it.
Old Dec 23, 2009 | 01:28 PM
ZippyNH's Avatar
ZippyNH
Yeah....put 3 or 4 gallons in it. Does sound like it must have bone dry....did you drain it before you worked on it? The tiny bit of gas in it must be slochibg around....
Old Dec 23, 2009 | 01:38 PM
skippydog's Avatar
skippydog
Its the Flux Capacitor The doc told me so!
Old Dec 23, 2009 | 02:24 PM
josh_r53's Avatar
josh_r53
cheers for the reply guys, em, i've put about 20 litres in it now, started and still getting the same problem,
i'm starting to think it may be like a coolant system safety cut out, the car runs for a while then when it starts to heat, thats when the car cuts out and continues to, then 10 minutes later when its cooled down, runs for a longer time agin. this is my line of thought seeing as i replaced the radiator
can anyone help on this? cheers again
Old Dec 23, 2009 | 03:38 PM
ZippyNH's Avatar
ZippyNH
Never heard of a safety shutoff!!!
the car will keep runnning....and overheat...the red idiot light will come on, and the head will crack, and the head gasket will blow. No such thing as a safety shutoff in the cooling system.....next guess!!!
Old Dec 23, 2009 | 04:01 PM
josh_r53's Avatar
josh_r53
hmmm, that makes sense to be honest,
I've been told, by my renault mechanic pal, it could be a simple electrical fault, a diagnostics computer could solve.
i really hoped it was a known error,
please keep the ideas flowin,
Old Dec 23, 2009 | 04:13 PM
ZippyNH's Avatar
ZippyNH
If the lights are not lit up on the dash, then there should not be any codes saved.....though you could watch to a minor extent what is happening as the car stalls.....
How much front end dammage was there??
Old Dec 23, 2009 | 04:37 PM
josh_r53's Avatar
josh_r53
the engine emission light and warning lights are on, but the emission light is on usually anyway due to exhaust and pulley, dont know what the yellow warning light means i've only seen it when i loose grip on the road or turn the traction control off.
the bonet was crumpled and the front engine left engine mount was snapped, thats been replaced,
Old Dec 23, 2009 | 04:49 PM
ZippyNH's Avatar
ZippyNH
Sounds like there is some "other" dammage. I would get it into a shop....might be cheaper than throwing parts at it, or breaking it trying to make it run.
Other than checking the electrical connections, like the one next to the air filter, there might not be a lot you can do without some tools that a shop would likely have. Since you did Jack the motor up to replace the mounts, I would check all the connections throughly!!
Old Dec 23, 2009 | 05:23 PM
josh_r53's Avatar
josh_r53
think i'll have to cheers mate,
Old Dec 23, 2009 | 06:09 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
the engine emission light and warning lights are on, but the emission light is on usually anyway due to exhaust and pulley,.....................
Old Dec 24, 2009 | 09:23 AM
ZippyNH's Avatar
ZippyNH
The pulley when done right will not turn on any lights....if anything it might reduce emissions since it will help to lean out our overly rich running motors....that might increase the NO2 levels a bit, but the 02 sensor is just looking at unburnt fuel.....sorry to go off on a tangent... But it looks like you had some engine troubles before you wrecked your car, thus making it hard to troubleshoot, even for a shop. I would get a pro's help.
Old Dec 25, 2009 | 08:35 PM
wdietz186's Avatar
wdietz186
Your Renault buddy should have access to a scan tool.If it is OBD2 compliant it will read the trouble codes that will affect the emissions and the codes are universal among manufacturers so if it an O2 sensor,throttle body,Idle control valve,etc the scanner should tell you. Thinking of it, it could be the IAC valve or a throttle body problem if it stalls after it comes off fast idle mode.The MAP sensor could also be damaged and telling the ECU it is running at 20,000 ft. and needs to be leaned out. The scan tool should have a data list and that will give you the sensor values to help you diagnose the problem.
Old Dec 29, 2009 | 04:42 PM
josh_r53's Avatar
josh_r53
i took the car into the shop today, after hours of diagnosing, they have concluded the pressure sensor is to blame for the idling issues, this is only £50 inc fitting
on an even worse note, however, i have been told the offside driveshaft is nachered, not the happiest person right now :(
Old Dec 30, 2009 | 08:42 AM
josh_r53's Avatar
josh_r53
fixed, drove the car home today, smiles all the way,
only one wee problem - the bonnet open light is on, obviously the sensor or something was damaged in the crash, anyone know where this is?
thanks,
Old Dec 30, 2009 | 07:02 PM
wdietz186's Avatar
wdietz186
I'm not positive but the switch is probably part of one of the bonnet latches.
iggi
18
Feb 9, 2026 01:00 AM
Bublik
Feb 18, 2023 11:09 AM
alistaircookie
Oct 8, 2015 10:52 AM
skippermini
Aug 13, 2015 06:13 AM
oldkid6
Aug 11, 2015 08:13 PM
