Whistling sound with Recirc off
Old Dec 10, 2009 | 10:42 AM
ECBerg's Avatar
ECBerg
For the past year I've been experiencing a whistiling sound at highway speeds, I originally thought it was a window of sun-roof seal, but then I discovered I could make it go away by a) turning the fan speed up, or b) turning recirc on. I found and old thread on this issue, but no clear fix.
https://www.northamericanmotoring.co...pitched+whin e
I've got an '05 Cooper S, and it didn't have the problem the first couple of years. Whistling appears to come from the passenger side. One other anectodal piece of evidence: At 85,000 miles I decided to start doing some maintenance myself, in particular "Inspection I": Oil, filter and microfilter. When replacing the microfilter I noticed that firewall side of the cover was broken and didn't latch, i.e., I'm not getting a good seal. I wonder if that may be the source (Onset of the issue coincides with last time dealer serviced my car...I wonder....).
Old Dec 10, 2009 | 11:29 AM
ntmid8r's Avatar
ntmid8r
It does sound like it is the microfilter cover not sealed.
I had the same problem when I changed mine and did not fit the cover on the entire way the first time.
It can be a little tight down there to see if it is clipped in correctly. I took an inspection mirror and a flashlight to check mine after installation.
Colt45Magnus
Aug 27, 2024 05:03 AM
Filmy
15
Jun 6, 2023 06:27 AM
atlantaorange
21
Oct 2, 2015 12:32 PM
Joeygonz
Oct 2, 2015 11:24 AM
schwac2
Sep 10, 2015 07:24 AM
