Blinkers/Signal lights hesitating
Old Nov 27, 2009 | 12:05 PM
Enano's Avatar
Enano
Hello all! Been browsing this forum for some time and I decided to register since I need your help and seems that this community is pretty helpful with each other
Little about my mini... I have a 03 R53 with 53k miles or so. I had it for 6 to 8 months now and I been doing regular maintenance myself since I got it. Car has 15% reduction pulley, alta intake and strut brace. Everything else is pretty much stock. I got the car when it had 47k miles.
Today on my way back to work I noticed when I put the signal lights (either left or right) the clicking inside started hesitating. It was not clicking on a constant beat. Sometimes it had like a half second delay for the next blink and sometimes clicks ahead of time. On my previous cars when the signal bulb went out, the car blinked faster but stayed consistent... which is not my case. So I got to work and I put the signal and tested both left and right... signal works on front and rear but inside has that hesistation problem and when I was parked, the right signal clicked just once then stopped but the lights outside were blinking.
I tried to search the problem and didnt find anything directly related to my issue. Sorry if it has been posted before. I even tried google and nothing.
Old Nov 28, 2009 | 03:33 PM
Enano's Avatar
Enano
Bump
Old Nov 29, 2009 | 01:38 AM
Enano's Avatar
Enano
Tonight on my way home I took advantage that it was dark and that way I could spot if the signal lights hesitate as well. At one point my signal light got stuck or hesitated faster or slower at times but noticed that the outside signal lights are turning on when they are supposed to and blinking normally. In other words, the problem could be inside since the outside light up just fine and blink like they are supposed to.
Old Nov 29, 2009 | 09:00 PM
Enano's Avatar
Enano
Anyone?
Old Jan 15, 2010 | 06:43 AM
Enano's Avatar
Enano
Oddly I replaced the stock battery with a optima red top and problem was solved immediately Red top fits perfectly as well. Recommend it.
Teh
Jun 13, 2018 02:59 PM
SunnySideUp
R57 :: Cabrio Talk (2009+)
Aug 26, 2015 01:16 PM
Ryephile
Aug 25, 2015 06:51 AM
Aug 19, 2015 12:51 PM
