Need a Picture or Pinout for 3-Pin CD Changer Cable
The connector for the 3-Pin CD Changer cable pulled loose when I was trying to get to the battery in my '03 MCS.
Which holes are the wires supposed to go in?
As you can see the connector holes are labeled 3-2-1 and there are red, black and white wires.
If someone could please take a look at which color goes in each number on the connector that would be great.
Or even a closeup picture of the side with the numbers on it would be fine.
The electrical diagram says:
pin 1 brown (ground)
pin 2 red/brown stripes (k-bus)
pin 3 white/red/yellow stripes (connects to a fuse, probably power)
But these colors don't match the ones you listed. Look at them more carefully and test for power and ground if the colors are in fact different.
Navigation & Audio HK Replacement With New Components
Filmy
15
Jun 6, 2023 06:27 AM
wildwestrider
Sep 4, 2015 06:25 AM
