brake fluid leak
Old Aug 22, 2009 | 12:16 AM
minIfrank's Avatar
minIfrank
brake fluid leak
hey everyone, i have a break fluid leak im pretty sure and im really nervous about driving i would llike to get this fixed asap i was wondering if i could just do it myself real quick or would you guys recommend me just bringing it to the dealer. i would love to have this fixed before monday. if anyone wants to help me im around yonkers new york. thanks all
Old Aug 24, 2009 | 12:28 PM
Cadenza's Avatar
Cadenza
It's Monday. Did you get it fixed? Where's the leak?
Old Aug 25, 2009 | 11:49 PM
minIfrank's Avatar
minIfrank
its seems to be dripping from the fluid tank..and no i havent fixed it yet..the brakes still work fine..jsut the DSC is off constantly
Old Aug 26, 2009 | 11:44 AM
Cadenza's Avatar
Cadenza
If it's leaking between the master cylinder and the fluid reservoir, a seal is weak and shouldn't affect braking power. But brake fluid is corrosive to paint, so you might want to check if Mini carries the individual rubber seal.
You would have to extract the fluid using a turkey baster, remove the reservoir and install new seals. The entire brake system will have to be bled to remove air bubbles.
If your pads are almost on their way out, I would replace them too since you have to remove the wheels to bleed the calipers.
Old Aug 26, 2009 | 09:05 PM
minIfrank's Avatar
minIfrank
thanks alot..im going to take it to a shop tomorrow since the dealer doesnt want anything to do with me
Old Oct 4, 2021 | 11:03 AM
Grand-Cayman's Avatar
Grand-Cayman
See this link for an explanation of how the brake master cylinder works. And you will realize from this why fluid leaking from the reservoir is not an issue with respect to braking.
squawSkiBum
Tires, Wheels, & Brakes
27
Nov 19, 2024 10:26 AM
Etrain
16
Aug 5, 2024 04:37 AM
HaveATank
Sep 4, 2015 08:04 AM
HaveATank
Aug 24, 2015 10:26 AM
Redhotz
R55 :: Clubman Talk (2008+)
Aug 14, 2015 05:29 AM
