Replacing headlight glass
Old Aug 9, 2009 | 06:08 PM
FLKeith's Avatar
FLKeith
I have an R56 with non-Xenon headlights and one of the headlights has several bad scratches from an encounter with a wire fence. Is the glass easily replaced? Where is the best place to get the glass from?
Old Aug 10, 2009 | 05:32 AM
Capt_bj's Avatar
Capt_bj
Entire light unit
I think the good news is since you don't have Xe's this won't be TOO expensive. I believe you'll need to replace the entire headlight unit which is actually fairly easy - unplug the wires, remove a few nuts and the assembly is easy to pull out. Well that's how easy it is on a GEN1 anyway. The lens is glued on, so there's no easy way to replace just the lens. (I replaced a guy's standard fixtures on a GEN1 with an angel eye set he got off e-Bay)
Start with the recomended low cost dealers who adv' here, and compare to your local guy. IME the light assemblies don't cost that much. Or at least I was happy with the cost from the dealer when I cracked a front turn signal / running light.
Old Aug 10, 2009 | 07:41 AM
schatzy62's Avatar
schatzy62
The light assemblies can be taken part but MINI does not sell just the lens, they only seel the whole unit.
You might be able to get a used one that is in better shape froma junk yard but other than that it is a dealer or OEM parts place part.
Old Aug 10, 2009 | 07:56 AM
lacning74's Avatar
lacning74
if you don't have 'em, an excuse to get a new assembly with clear turn signals?
Alkaidovich
Jan 30, 2021 01:35 AM
Rai1gun
R60/R61 Stock Problems/Issues
Jan 11, 2016 05:52 AM
Alkaidovich
Aug 30, 2015 09:04 AM
R53Mom
Aug 17, 2015 01:38 PM
