Drivers door window dipper
Old Sep 28, 2009 | 08:07 PM
  #176
RJKimbell's Avatar
RJKimbell
Well I've somehow misplaced my Receipt, but I remember it saying "initializaiton", so I'm not sure if this will actually work or not...so far no issues.
Old Oct 19, 2009 | 03:39 PM
  #177
MiniDad08's Avatar
MiniDad08
MiniDad09
Any New Fixes for the Window Dip Problem?
Our 2009 Mini Cooper with 5200 miles has just started experiencing the window dip problem where the driver side window will not complete close/seal when you open and close the door. Pressing the window in from the outside or raising and lowering the window from the inside will result in the window sealing properly.
It just started getting colder in our area (35-45 degrees). It appears that the window motor will not "dip" the window far enough down when the door is shut resulting in the top rear of the window hanging up on the roof molding. I'm hoping for a "one trip" fix from Classic Mini.
Other than the above mentioned problem, we are extremely pleased with our 2nd Gen Mini. We also owned a 2005 CVT
Regards,
Old Oct 20, 2009 | 07:53 AM
  #178
strobeyprobey's Avatar
strobeyprobey
The driver side window in '09 loaner car I had last week had "lost" its program even. No dipper, no auto up. Ugh. I am not looking forward to post-warranty years of going to the dealer for reprogramming! I hope they can FIX this issue before my warranty runs out. I wonder if this is a DIY option with the Minitechinfo site and the J2534 computer interface?
Old Oct 20, 2009 | 08:32 AM
  #179
gaffer's Avatar
gaffer
The driver side window on our '09 Clubman @ 10,000 miles is not dipping correctly when the door is opened. It may dip about 1/10", it's not really dragging on the top trim. Can't be good for the seal though. Tried holding the toggle 15 seconds in the down position and the same in the up position; didn't fix anything. Will wait until the next oil change to get "repaired" at the dealer.
Old Oct 21, 2009 | 10:22 AM
  #180
MiniDad08's Avatar
MiniDad08
MiniDad09
The "Repair" for our Window Dipping Issue
Invoice (0.00) states the following:
"FRM Software Program and Code Control Unit Initialize Windows CHK
and Grease Door Harness per SI M51 01 08"
Note: The SA first indicated that the FRM module may need replacement. He then came back and indicated that it would need re-programmed (about a 2 hour process).
THE BENEFIT of THIS REPAIR
I was able to speak with our really good looking MA (Tiffany) for almost two hours Classic Mini is a great place with very helpful SA's and MA's.
NOTE: All the attempts for a self fix (holding the switches for this many seconds open/closed, etc. never worked for me.
NOTE 2: This window issue started right after I did not close the door all the way the first time. I wonder if the door dips then hits the frame which results in altering or finding a bug in the software program???
Old Oct 21, 2009 | 04:40 PM
  #181
jjshoe's Avatar
jjshoe
07 coooper (not s) I've had the footwell module replaced. In my case the window wouldn't go up and the car didn't see the door as closed, so I would have to take the key out of the fob to lock it. It took them over a week to do the work, and they put me in a vw rental car, with, you guessed it, broken windows.
real pita.
one of many reasons I hope someone totals my mini in a non-injury accident. This car will be a real nightmare out of warranty.
Old Oct 25, 2009 | 07:03 AM
  #182
pxtech's Avatar
pxtech
I just got my 09 Coop S fixed for this very same issue. Less than 4000 miles on it and the drivers side window would not dip when opened. When closing the door the window would catch on the roof and the door would not shut they did a software update its been fixed for a week. Hopefully no more window gremlins.
Old Oct 25, 2009 | 09:23 AM
  #183
Xymox's Avatar
Xymox
Originally Posted by jjshoe
One of many reasons I hope someone totals my mini in a non-injury accident.
WOW! Yikes! That's harsh!
This car will be a real nightmare out of warranty..
Personally, I'd never own another one (at least a Cooper S) out of warranty.
Old Oct 26, 2009 | 08:38 AM
  #184
gaffer's Avatar
gaffer
The window has now mysteriously gone back to normal!?!?
Old Nov 6, 2009 | 06:02 PM
  #185
mellocooper's Avatar
mellocooper
Mines been perfect ever since reprogramming at bill Jacobs mini almost a year ago.
Old Nov 7, 2009 | 09:47 AM
  #186
redevil's Avatar
redevil
my Mini just stopped dipping when opening and closing. Have to book it with the dealership to get them to fix it.
Old Nov 10, 2009 | 02:56 PM
  #187
Flytime's Avatar
Flytime
Pass side window dip and auto up trouble
My Pass side window would drop with opening the door, but not go up (door closed) also the auto up function stopped working.
For me the reprograming by holding the switch in the full down for 15 seconds and then full up for 15 seconds worked to restore the passenger side window dip function and auto up function. I had to do try it twice, first time ignition on, engine not running, the second time running. Interestingly the phone didn’t automatically sync with Bluetooth after this.
Old Nov 11, 2009 | 07:01 AM
  #188
Nynomad's Avatar
Nynomad
I had the dip problem on my drivers door. I checked the molding on the top part where the window closes into (or supposed to). It was all folded over - I straigtened it out and a day or two later the window dipped as normal. I tried the holding the switch in the open and closed position - rolled the window up and down. Maybe it "learned" what it was supposed to do. Any way I had three days of a non working window dipper - then I fixed the molding and it has worked for over a week now - Fingers crossed....
Oh while it wasn't working I found after opening the door I could push down on the window while the door was open so that when I closed the door the window would not be on the outside of the molding when the door was closed.
Old Nov 30, 2009 | 10:01 PM
  #189
DrSelina's Avatar
DrSelina
Crap!! Simone and I have been doing just fine. I got her in May, she has less than 4K on her, now the trunk door keeps spontaneously unlocking(for about a week and a half now), the driver side window won't dip (started today), and when I went to start her up today, she gave me the yellow car up on stilts pic with something about the battery having excessive discharge. She is going into the dealer's first thing Thursday morning. But my question is..should i be worried that all these things are going wrong with less than 4k??
Old Dec 3, 2009 | 01:19 PM
  #190
DrSelina's Avatar
DrSelina
Dropped Simone off early this morning. I am really hoping they can fix all the problems. Actually, for all the money I paid for this car, they BETTER fix all the problems!!
Old Dec 3, 2009 | 04:49 PM
  #191
DrSelina's Avatar
DrSelina
Got Simone back. The window was reprogrammed and works now. The trunk locking mechanism was malfunctioning because of a faulty seal in the handle. Water had gotten into the handle and corroded the mechanism. I just realized I forgot to tell them about the seatbelt
Old Dec 3, 2009 | 05:44 PM
  #192
SmokeM's Avatar
SmokeM
Its sad that you have SO many problems you "forget" to tell them all. It shouldn't be this way given the cost of these cars. My passenger window is acting strange...it doesn't one touch up when I do both windows at the same time. It will actually go up then down (or stop).
Old Dec 4, 2009 | 04:39 AM
  #193
MiniDad08's Avatar
MiniDad08
MiniDad09
Reprogramming (a several hour process) fixed the problem on our 09 Mini. It's been several months and no problems. I tried all the self help programming procedures listed (Holding the switch, etc) without success.
Old Dec 4, 2009 | 05:59 PM
  #194
DrSelina's Avatar
DrSelina
I totally agree!! However, I got in this morning and noticed the seatbelt was correctly wound. I wonder if someone took it upon themselves to fix it??
Old Dec 8, 2009 | 09:50 AM
  #195
pxtech's Avatar
pxtech
my coop S 5000miles is back in the shop to fix the window dipper issue again and to fix the CEL it threw this morning. we'll see what the cause is and if they get it fixed or not.
Old Dec 8, 2009 | 12:44 PM
  #196
djdnz's Avatar
djdnz
Well this happened again to my girlfriend's car. It was working for about 8 months and now the cold weather has come again and it stopped working. We took it to mini, they had it for most of the day to reprogram it, and it's back now and working properly.
I'm really curious to see what they actually reprogram with the thing.
Old Dec 9, 2009 | 08:29 PM
  #197
minimikebc's Avatar
minimikebc
Took my 2008 in last week for the window problem and they needed the car for most of the day to reprogram, and did tell me that the new window fix was loaded. Windows now work properly.. but now have to take it back as the brakes are mushy after they flushed the brake fluid...one problem down, one new one to replace it!
Old Dec 23, 2009 | 12:39 PM
  #198
miniclubman's Avatar
miniclubman
I have my doubts about whether the window"fix" is a fix at all.
My '08 Clubman had the window-dip issue last spring, and they kept the car for the day and reprogrammed, and now the exact same issue has reappeared. This time I'm going to ask the dealer what this repair costs, and whether MINI will have a program to extend the warranty for this common defect.
Based on their answer I may decide to sell before my four year anniversary. I love my Clubman, but the inability of MINI to fix this and other glitches (like the sunroof opening issue) makes me very wary of owning a MINI once the warranty is up.
Old Dec 23, 2009 | 02:16 PM
  #199
toolazyforalogin's Avatar
toolazyforalogin
has your footwell module been replaced?
Old Dec 23, 2009 | 03:58 PM
  #200
minimikebc's Avatar
minimikebc
My fix did not include any parts replacement, but updating the code in the computer.. they indicated that there was a fix released in late October, so this along with a few other updates were done to my car..so far no window issues. If the last time you had the windows 'fixed' was in the spring, you should be able to get the new updates loaded for your car as well.
