drivers door lock... problems....
Old Aug 13, 2008 | 07:14 AM
pimpedout97x's Avatar
pimpedout97x
This is what's been happening for nearly a year with just my drivers door. The passenger door works 100 percent fine.
Read carefully as its easy to get this mixed up.
My drivers door will lock fine with the remote or the toggle switch inside.
It WILL NOT unlock by the remote or toggle switch. I have to either unlock it manually with the key, or if I'm inside, just pull the inside handle and it'll unlock like its supposed to.
I've looked in the door and no cables/rods seem to be loose/disconnected.
HOWEVER...
When I press unlock on the remote or toggle switch, as I stated previously, it won't unlock the drivers door, but you DO hear the click noise that the mechanism makes, as if it is TRYING to unlock it. So it DOES register when I press unlock, or hit the toggle inside to unlock, but it won't actually unlock the latch.
Again, it does LOCK fine..just not unlocking.
Any ideas? From what I would think, if the mechanism/actuator was bad, it wouldn't lock OR unlock, and it wouldn't make the noise like its unlocking it...
The part from MINI is 147 dollars. Can this be had for cheaper elsewhere, and still be good quality?
Old Aug 18, 2008 | 06:42 PM
sarahari's Avatar
sarahari
Did you figure it out? My wife's car is the same thing, same model year.
Old Aug 19, 2008 | 10:32 AM
pimpedout97x
Nope. I guess ill just have to pay and get a new part.. :-(
Old Aug 19, 2008 | 04:08 PM
xnotfunkylex's Avatar
xnotfunkylex
You need a new door lock actuator. I had that problem also. Replaced it and now it works fine. I think its like $120-$150 for the part.
Old Aug 19, 2008 | 05:17 PM
volki
Have you seen this thread?
https://www.northamericanmotoring.co...ad.php?t=99835
Lots of good information there if you are planning to fix it yourself, where to get the actuators, etc etc.
Filmy
Sep 7, 2015 08:27 PM
F55MidnightBlackCooperS
Sep 3, 2015 04:02 PM
Southern Marylander
Sep 3, 2015 05:46 AM
Ntety
Sep 2, 2015 08:39 PM
Suspension Products
Sep 2, 2015 10:32 AM
