#1 injector not getting power. NEED HELP ASAP
Old Aug 11, 2008 | 06:29 PM
tmex05's Avatar
tmex05
I have a 2002 non s copper. I thought my injector number one went out it wasn't getting any power so i figure it was dead. I swap out the injector today. Found out that the injector wasn't bad. I check for power where the plug was it wasn't getting any ground. Anybody have any idea where the short might be or has ever ran in to this problem???
Old Aug 11, 2008 | 06:40 PM
Dr Obnxs's Avatar
Dr Obnxs
No, first I'd heard about it...
the injector fires directly from the ECU, so you can test the points on the ECU harness. If it's not there, then the ECU is toast (it has high current transistors to drive each injector). If it's working there, you have an open in the wiring harness.
Matt
Old Aug 11, 2008 | 07:20 PM
tmex05's Avatar
tmex05
Matt
Thanks for the fast reply. Do you know which pin it is to test on harness?
wildwestrider
11
Jan 29, 2016 05:06 PM
randeez
Oct 5, 2015 09:23 AM
cub4bearindiana
Oct 2, 2015 09:45 AM
WhinyR53
Sep 30, 2015 07:36 AM
dutchhome
Sep 30, 2015 07:17 AM
