Power steering fan shroud install....??
Old Aug 26, 2003 | 03:03 PM
antsmini's Avatar
antsmini
Has anyone installed the power steering fan cover from moss? Reason Im asking is because I am wondering if I have to remove the power steering fan to do the install, or can I just do it from under the car?
Old Aug 26, 2003 | 03:15 PM
ronvan's Avatar
ronvan
I was under my car yesterday checking things out and from the picture you attached I think it would be easy to install from under the car. Hardest part would be putting the car on jack stands and crawling underneath. :smile:
Old Aug 26, 2003 | 06:47 PM
BOSSMINI's Avatar
BOSSMINI
Just install shroud last week,very simple.Once car is on ramps a10min job,two bolts.BE VERY WITH THE CONNECTOR OR YOU WILL BREAK THE LOCKING CLIP ON IT,IT IS NOT REPLACEABLE.Good luck.
Old Aug 26, 2003 | 08:24 PM
antsmini's Avatar
antsmini
BOSS, can you please explain. Is the clip on the fan or the shroud itself?
Old Aug 27, 2003 | 06:16 AM
BOSSMINI's Avatar
BOSSMINI
The clip is on the electrical connector you must unplug to remove the fan.The instructions with the shroud will show you the connector.Really easy just dont rush when unplugging the connector.
Old Sep 1, 2003 | 02:31 PM
zgokart's Avatar
zgokart
__________________-
I'd recommend getting the Rhino ramp, available at Kragen's or Walmart. $19.95 at Kragen's. The ramp can support up to 12,000 lbs weight. I paid a little more at Walmart, but then, the price may have come down a bit.
Old Sep 1, 2003 | 02:36 PM
zgokart's Avatar
zgokart
_____________________---
I'm curious as to why the electrical connector has to be unplugged in ordere to install the new shroud. I thought the shroud just bolted to the housing with two bolts. Is there a technique to unplug the electrical connector? Pull slowly straight out or wiggle and pull out? TIA.
Old Sep 1, 2003 | 02:40 PM
Technomage's Avatar
Technomage
I installed mine in about 5 min.
Just put the car on ramps, Undo 2 bolts, unplug the fan, put the cover on the fan, plug it back in, replace the bolts. All done under the car.
Old Sep 4, 2003 | 08:40 AM
MINIAC's Avatar
MINIAC
Once the shield is slid onto the fan, how hard is it to "bend the shield at the perforations to align the two mounting holes"?
Manny_cooper
Sep 10, 2015 11:09 AM
bansasn
15
Sep 4, 2015 01:24 PM
Aug 25, 2015 09:33 AM
coachvminis
Aug 25, 2015 06:58 AM
minipopkart
Aug 13, 2015 05:22 AM
