JCW intake install, ECU connection help?
Old Jun 7, 2008 | 03:27 AM
hoonpv's Avatar
hoonpv
following the instruction, I have connected white/pink = yellow by twisting it.
and now I have to somehow connect the twisted wire to the other white/pink from the connector.
problem is that, the line from white/pink is too short... is there anywhere I can do this? i'm sooo not good with electrical stuff....
I wonder if radioshack carries something to mend this..
Old Jun 7, 2008 | 08:15 AM
chadtoolio's Avatar
chadtoolio
The kit came with a heat shrinkable butt connector. The red/white wire goes to the DME. Cut that wire, twist the yellow to the red/white wire. Now you have a yellow and red/white wire twisted together and the other end of the red/white wire that you cut earlier. Use the butt connector to crimp them together.
HTH,
Chad
Old Jun 7, 2008 | 09:16 AM
BlimeyCabrio's Avatar
BlimeyCabrio
Correct. You use the crimp connector that came with the kit. Careful - you only get one try. You need to use a CRIMPER - not pliers - to do this right... cheapo crimper from radio shack, walmart, or wherever will work.
You may also need to carefull but firmly pull on the "car" end of the red/white wire to "stretch" a bit more of it out of the harness to have enough length for a good connection - I had to do that...
Old Jun 7, 2008 | 11:51 AM
Crashton's Avatar
Crashton
+ 2.....
Twisting those wires together & not using a proper connector is asking for problems down the road.
Old Jun 11, 2008 | 10:57 AM
//MZero's Avatar
//MZero
hmm...I "twisted" the wires together as per the instructions, and have no problems. However, I did things a little differently. I did not actually cut the White/Red wire I simply removed the insulation from it over about 1/2" or so. Then I took the yellow wire and sort of split a couple of the wires apart, spread the now exposed wires of the white/red wire, put the yellows wires through and twisted everything together that way, then wrapped it up very tightly with electrical tape and heated it a bit to shrink it. I have used connectors many times in the past, but I did not want to cut the wire going to the DME. The method I used was very strong, I tugged on it a few times with no movement what so ever before taping it. If it ever did have a problem I would simply soder it. I think this method is a good alternative to those who don't want to actually cut the wire, and want something EASILY reversible.
Now if you cut the wire and just twist all three ends together...no that wouldn't be good and would eventually probably come apart unless sodered.
Old Jun 12, 2008 | 08:54 AM
chadtoolio's Avatar
chadtoolio
That's how I install the Lojacks..., just pull the insulation back. But since the JCW kit says cut, I cut. If there is a problem with it later, the manufacturer who makes the install instructions can't fault me.
09R56
Nov 16, 2022 10:49 AM
Alkaidovich
Jan 30, 2021 01:35 AM
minimofo
Apr 4, 2016 07:36 PM
Dec 23, 2015 10:36 AM
