Electrical Gremlin...HELP!
Old May 28, 2008 | 04:11 PM
ACEkraut11's Avatar
ACEkraut11
Try this one out. Hopped in my 2002 MCS to drive home tonight and the driver window doesnt work but the passenger does. I try the driver switch and can hear clicking from around the center of the dash but nothing happens. I have the auto-up installed so I figure maybe that has gone south. I get home and access the back of the switch panel and remove the auto-up and try everything again. Now nothing works. So I hook up the auto-up again. Try the switches. Nothing from the drivers side and the passenger side goes down when I push the switch up but does nothing when I push down. So I take off the auto-up again and try everything out. Now the central locking switch makes the passenger side window go down and nothing else works on the switch panel. I can still use the key to lock the door and to put up the passenger side window and the key still locks and unlocks the door. Anybody have an exorcism ritual they can recommend?
Old May 28, 2008 | 04:41 PM
MRmidge's Avatar
MRmidge
Sounds like the gremlin has already done it's damage and left. I'm guessing something shorted out. When you short out silicon boards they can do some crazy things. As to what you would specifically need to replace i have no idea.
Old May 28, 2008 | 04:43 PM
DPCooperS's Avatar
DPCooperS
I
Old May 28, 2008 | 04:45 PM
DPCooperS's Avatar
DPCooperS
I would disconnect the battery for a while to reset the system.
Old May 28, 2008 | 06:53 PM
ACEkraut11's Avatar
ACEkraut11
I wondered about that. Battery is disconnected. I will report results in a bit when I hook it back up.
Old May 28, 2008 | 07:04 PM
ACEkraut11's Avatar
ACEkraut11
Incidentally, before I disconnected the battery I turned on the running lights and didnt see any interior lights around either the switches or the heating, fan controls, etc. Can someone refresh my weak memory as to what lights show for those controls? I am wondering now if there is a fuse blown? The defrost light and the AC light both work.
Old May 28, 2008 | 09:04 PM
ACEkraut11's Avatar
ACEkraut11
Thanks for the suggestion DP, that did the trick. Well, it didnt do anything at first but when I reseated the connection it finally allowed everything to work again. I will reset my stereo tomorrow. Thanks again.
Old May 29, 2008 | 04:58 PM
zagadka's Avatar
zagadka
i'll have to try this. my windows are doing the same thing, plus the radio didn't work one day this week, and once last fall no lights interior or exterior came on. ghooooooosts!
Old May 29, 2008 | 07:17 PM
ACEkraut11's Avatar
ACEkraut11
I learned something new today. When the battery is disconnected the radio doesnt lose its settings. Although the trip odometer did reset to zero.
USNAE2
16
Jun 17, 2022 07:17 AM
ryGuyMCS
Oct 6, 2015 12:04 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
FatherG
Sep 27, 2015 05:12 AM
asmasm
Sep 21, 2015 08:23 AM
