Lubing your door hinges
Old May 9, 2008 | 12:20 PM
Yo'sDad's Avatar
Yo'sDad
Wondering if anyone has lubricated their door hinges. I'm not talking about hitting it with a spray can of wonder juice. I'm talking about pulling the hinge pin and lubing with grease?
I'm also thinking about drilling/tapping and installing a grease fitting. If I ever pull the headliner down at the rear, I plan to do this to the hatch hinges.
I keep cars a long time and almost every car I've every owned wears out the drivers door hinges and then the door sags. I'm just trying to prevent this on my MINI.
Mayhaps, I might be the first, so I'll post pics and how it went.
YD
Old May 9, 2008 | 12:50 PM
herbie hind's Avatar
herbie hind
wow
Old May 9, 2008 | 10:19 PM
Ancient Mariner's Avatar
Ancient Mariner
I really like the idea of grease fittings on the rear hatch hinges. Love to see what you can come up with. If you use juice that's thin enough to penetrate completly, it dosen't last very long. Anything thick enough to last dosen't penetrate. Gotcha.
-skip-
Old May 9, 2008 | 11:14 PM
ScottRiqui's Avatar
ScottRiqui
I like the idea of tapping the hinges for grease fittings, but I think I would have to consider what's involved in fixing a "sagging door" problem if it ever happens. If there's a sacrificial bushing in the hinge that can be easily replaced along with the door pin, I'd probably just buy a few extra pins/bushings and replace them if/when the hinge starts to get "sloppy", rather than periodically disassembling the hinge throughout the life of the car to lube it.
Old May 10, 2008 | 09:14 PM
Ancient Mariner
Kinda hard to see, but it dosen't look like there are bronze bushings in the door hinges. More's the pity. That's a lot of door hanging from those pins, but after six years there is no discernable sag. (knocks on wood)
-skip-
Old May 21, 2008 | 12:53 PM
joedude99's Avatar
joedude99
Lube
I used silicone bedroom lube and it worked great and never squeaked again.
Old May 21, 2008 | 02:39 PM
bthayer23's Avatar
bthayer23
How do you get "bedroom lube" into a grease gun? Also, I thought it was water-based?
Old May 21, 2008 | 10:58 PM
Ancient Mariner
And is there wine, soft words and a candle-lit dinner involved in this "bedroom lube" process?
Old May 22, 2008 | 04:58 AM
joedude99's Avatar
joedude99
Bedroom Lube
Some bedroom lube is silicone based. Watch spilling it on the floor because it's really slick. LOL
Old May 22, 2008 | 08:58 AM
Eric_Rowland's Avatar
Eric_Rowland
Converted garage?
Old May 22, 2008 | 10:40 PM
Ancient Mariner
Originally Posted by Eric_Rowland
Converted garage?
Nah. Tough love. (and cold concrete)
Old May 23, 2008 | 06:28 AM
ridingfar's Avatar
ridingfar
I've used either red or white lithium grease on door hinges with good success for ~40 years. Spray the hinge joints lightly and dont wipe off the over spray for a week or two. Enough penetrates to the hinge pin to help keep moisture out and lube the pin to hinge bearing surface. I do this when I change oil or spring and fall, which ever comes first.
Grease fittings sound like over kill for door and boot hinges.
Old May 23, 2008 | 06:33 AM
planeguy's Avatar
planeguy
YD
you must keep your cars for a long time because I havent seen a car with sagging door disease produced since the early eighties, and most of those were GM pieces of crap at that.
Old May 23, 2008 | 10:53 AM
diptenkrom's Avatar
diptenkrom
cavalier i had did that bad... but for a free car, you can't complain.
also a firebird, but it was a 99.
so +2 on the "GM pieces of crap"
Old May 23, 2008 | 10:59 AM
joedude99's Avatar
joedude99
Sagging Doors
I have a heavy buddy whose Voyager minivan had sagging door disease.
Old May 25, 2008 | 05:50 AM
ridingfar's Avatar
ridingfar
I'd bet he pushes down on the door to hoist himself in and out of the car. I've seen that done by heavy folks, and short guys climbing into tall trucks. The result is not so much worn hinge pins but twisting the hinge plates on the door frame/car body.
Lube wont prevent or cure that....
Filmy
15
Jun 6, 2023 06:27 AM
Norton70
Feb 2, 2017 01:06 PM
keen
Nov 14, 2015 02:08 PM
Juan Baddoggi
Sep 24, 2015 06:34 AM
Filmy
Sep 7, 2015 08:27 PM
