Gas Gauge Problem!!!!!
Sounds poorly designed to me. My Jeep has an accurate reading for Miles To Empty as well as the gas gage.
The excuse for the odd shaped gas tank is lame. While the fuel tank float is electromechanical I can almost bet that the signals it's generating is converted by the "brain" for display. So some where during the conversion process some programmer programmed the wrong thing into the chip?
Why motorists are getting stranded because of a gas gage that is displaying inaccurate information is beyond me. They sure got the folding mirrors to work properly. Is an accurate gas gage too much to ask for in this day and age ?!
Here in northern California where electricity is unreliable (earthquake, forest fires, landslides, redwoods falling, etc.) I never let the tank get less than half full because I don't want to get caught without enough gas to get home.
Keeping an eye on the trip odo reminds me thats how I monitored the fuel level on my motorcycles.
I've never even looked at the "miles remaining" number. Doesn't sound reliable to me.
The excuse for an odd shaped gas tank is not lame. I used a conical shape for example. No doubt your Jeep has an almost square tank. Most cars' tanks are not due to the design of the car. Crawl under a few and have a look. But then again I guess you're perfect and don't need to.
I use to agree with that except my other daily driver tells you pull the fuel pump fuse, start the engine and run it until it dies to purge the fuel pressure out of the lines prior to changing fuel filter. I had always heard it was bad but this car has been fine for 215K miles and I've done that at least half a dozen times to it. It's a fuel injected Nissan.
Not that I plan to run out of gas in the Mini.
Do not continue driving to the point where
the fuel tank is totally empty. Otherwise
engine performance is not guaranteed and
damage could occur.
damage could occur.
Like I said, the Nissan manual says the opposite. There is no reason to run a tank dry. You're not gaining anything by not filling up once you hit 1/4 tank.
Obviously MIni recommends this for a reason. Not that everything in the manual is 100% accurate.
i usually fill up at the 3rd or 2nd (red) mark. Ive gone down as far as 1 where it told me i had 26 miles left. Never will i do that again even though i never ran out of gas.
I can get about 400 miles worth of orange marks, then i fill up.
if you read the 2008 manual for the MC/MCS it states that nothing is guaranteed once the range on the OBC reads 30 miles or less. This is due to the fact that it is just making an estimate and it's hard to be right on.
I think the OBC is just for entertainment.
The average mpg is never correct. I calculate the real mpg when I fill the tank and the OBC is always several mpg higher than reality. The average speed is never correct. An as for the estimated miles per tank, it always starts high and then closes to the distance actually traveled as the tank empties...
(Kinda like weather men who are never right 3 days out, but always correct on the current weather.)
But the gauge, while not linear in its response, is at least repeatable. I always refill with 3 bars left. ~11 gallons.
).Very interesting about the gas gauge falling slowly at first then dropping very rapidly. I noticed this as well, but thought it was just me...
The amount of fuel, it's level, anywhere inside a gas tank can easily be measured. I don't understand why this is even an issue. I guess I'm irked because I too was left roadside because I didn't have enough fuel. But, in my situation, I didn't listen to the gage and and tried to make it to the "next" gas station. That was my fault.
R50/53 R53 Chrono Pack - gauge?
missinmyjeep
Aug 22, 2015 07:13 PM
dchang0
Aug 10, 2015 03:37 PM
