Radiator fan resistor...
Old Mar 2, 2008 | 05:22 PM
gclass's Avatar
gclass
Anyone knows were i can get the resistor (green device) of the Radiator Fan. I was thinking that if this is the problem why not just change it, instead of buying the whole assembly. I have included a picture for reference.
Old Apr 23, 2008 | 06:23 AM
gokaht's Avatar
gokaht
I need the same thing - did you have any luck?
Old Apr 23, 2008 | 08:22 AM
gclass's Avatar
gclass
Resistor
Well so far I found a resistor from Ford Escape 02 which is the same thing (control fan speed) and look the same too. However, i'm currently running the fan without the resistor. Meaning: im still using the old fan but always at high speed and no problem so far.
Old Apr 23, 2008 | 10:41 AM
Grahamxx's Avatar
Grahamxx
I had the same problem hee in the UK, had to buy a complete fan unit as you can't buy the resistor separately!
Old May 12, 2008 | 10:17 AM
JeffM's Avatar
JeffM
I'm jumping in a little late here, but my low speed fan is inoperative so I'm interested in the topic. Is it possible to replace the resistor without disassembling the whole front of the car, if we could find a suitable replacement part? I don't want to buy a whole new fan assembly just to fix this, but my main issue is with the work involved to R/R it, not the price of the part. I'd love to find a simple fix!
Old Jun 16, 2008 | 12:21 PM
tayana's Avatar
tayana
Fan resistor
Our 03' Mini has a bad low speed fan resistor as well and I was curious if you had been able to locate a replacement.
Jerry
Old Jun 16, 2008 | 12:44 PM
JeffM's Avatar
JeffM
No, unfortunately I never found a replacement for just this part. As best I can tell, the only solution is to replace the entire fan assembly. I just ordered one today, and will tackle the job in mid-July.
FYI, Classic Mini in Ohio is having a parts deal this month (ends 6/30) where all parts are only 10% above cost. This makes the fan assembly under $200, which is quite a savings. So if you need this done, now might be a good time to order the part at least.
https://www.northamericanmotoring.co...d.php?t=142314
Old Jun 19, 2008 | 06:11 AM
tayana's Avatar
tayana
Did you ever install the Ford resistor? I assume this was just the low speed resistor and not the whole fan control unit form Ford?
Jerry
Old Aug 11, 2008 | 07:28 PM
CSIBMINI's Avatar
CSIBMINI
Any new info on the replacement resistor?
Brad
Old Aug 15, 2008 | 10:03 PM
rjtrout2000's Avatar
rjtrout2000
I hope this is not the case. I have been told that this is the part that may be faulting on my mini. The low speed fan doesn't come on at all, but that wouldn't be a bother if I was able to drive the car without the car power surging. The surging only happens when the A/C is on, so we will see what the diagnosis is soon...
Old Aug 17, 2008 | 03:39 AM
thx11381's Avatar
thx11381
You may want to check out RockAuto.com, they list a fan assem. at about 81.00 for 03/03 build dates and above.
Old Sep 6, 2008 | 04:26 AM
thx11381's Avatar
thx11381
Update: Rock Auto fan assem. comes with the resistor, Low speed fan is now operational, approx. 1 hour to replace. you only need to tilt the rad at the top to unclip the fan on its 2 lower attachment points. (after the condensor is loosened) Just make sure to support the ac condensor so you do not damage it.
Old Sep 6, 2008 | 04:42 AM
Warped1966's Avatar
Warped1966
Were any of you able to see numbers on the resistors? Manufacturer info? I bet if you took them to a good electronics parts supply store, and Radio Shack doesn't count as one, they would be able to get you one. It might not look exactly like the stock part but it would do the same job. Just food for thought.
Old Sep 6, 2008 | 05:10 AM
thx11381's Avatar
thx11381
I am in Va. Beach, you can have the old one. PM for address
Old Sep 11, 2008 | 06:36 AM
cycleway4's Avatar
cycleway4
Hi....I ordered one of RockAutos fan assemblies,.....yes it did have the resistor,.......NOTE***did have the resistor....it was laying in bottem of box.
Looks like someone ordered the assembly, removed the resistor, put their old one in the box,...and sent it back.
So,....I returned it again,....DOA. Part is no longer carried by RockAuto.
Guess will try another source,
The fan assembly, by the way, looked to be really nice quality. Made in Taiwan, not China.
Steve
Old Sep 11, 2008 | 06:44 PM
Warped1966's Avatar
Warped1966
I don't want or need the old one. I have an R56 so mine is probably different. What you need to do is have a sparky (electrician) go test a good one with an ohm meter and see what the resistance is then get one that matches that from a reputable electronics store.
Old Sep 11, 2008 | 10:17 PM
Ancient Mariner's Avatar
Ancient Mariner
Not just the ohms that need checking, but the wattage rating. Power rating of a resistor is very important when it's used on something that draws as much amperage as an electric motor does. Might get lucky and see the rating stamped on the old resistor.
Old Sep 12, 2008 | 04:29 AM
cycleway4's Avatar
cycleway4
the resistor was stamped .34 ohms...........as AncientMariner said, it would also need to be of sufficient specs to handle the amperage of the fan motor.
Steve
Old Sep 12, 2008 | 12:45 PM
Warped1966's Avatar
Warped1966
See? I'm obviously not a sparky!
Old Sep 12, 2008 | 02:02 PM
Tom D's Avatar
Tom D
Is there any other writing on the resistor besides .34 ohms?
Old Sep 13, 2008 | 12:24 PM
cycleway4's Avatar
cycleway4
nothing on mine.
Steve
Old Sep 22, 2008 | 05:33 PM
cycleway4's Avatar
cycleway4
Well, returned the defective fan assembly to RockAuto,...got my refund immediately,.....and have received another complete assembly from GoParts.com..........all parts are there,..looks really nice......$82.00, same price as RockAuto [who no longer carries the part].
Steve
Old Sep 23, 2008 | 05:54 AM
cristo's Avatar
cristo
Alliance Member
I can think of 2 ways to figure out the power requirements. V = I*R,
and P = I*V or V*V/R or I*I*R.
If you have a good resistor, then measure the voltage drop across it
when the fan is running and the resistor is active in the circuit.
Then power in watts would be V*V/R.
For instance a 4 V drop across the resistor would result in 47 watts,
so you'd need something rated a bit higher than that for this example.
If you don't have a functional resistor to test, then you can run the fan
straight off the 12V battery (probably 13.5V or more if the car's running)
and measure the voltage drop on it, and the
current draw in amperes as well. Then you can figure out the effective resistance
of the fan (R(fan) = V(across fan)/I(through fan), and when it's in series with the resistor which you know is .34 ohms,
then I = V (13.5 or so)/(R(fan) + 0.34), and power will be I*I*R.
Old May 15, 2011 | 10:03 PM
minirayofsunshine's Avatar
minirayofsunshine
ps problem
hi to everyone
it would appear from reading the posts on this topic that i have the same problem as quite a few people.
a couple of days ago i turned off the ignition and the ps pump fan kept on running, as i was somewhere a little remote i decided to head back only to have my ps fail about 500m down the road.
i have removed the fan and hooked it up to 12v, it runs fine.
someone told me if i lift the car and turn the steering back and forth the fluid in the ps reservoir should move if the pumps ok (is this right?)
also i have located the offending resistor that a few of you have mentioned, but am unable to gain enough access to it to remove it, i have unbolted the radiator but it doesn't move forward far enough. If i do manage to get the resistor out is it the small one or the big green one?
Any help or tips would be greatly appreciated.
martin
Old May 16, 2011 | 07:43 AM
cristo's Avatar
cristo
Alliance Member
You need to put the car in "service mode" if you haven't already done so
and unclip the top radiator hose to move the radiator forward.
Then you can unclip and lift out the fan assembly fairly easily.
It's the big green one - not even sure what that smaller part is.
BTW - here's the BIG thread on this subject:
https://www.northamericanmotoring.co...-solution.html
