My MCS Rattles like hell!!!!
Old Feb 28, 2008 | 02:13 AM
FreeSpirit's Avatar
FreeSpirit
Hi can anyone help me??
I have an 06 MCS with a full milltek exhaust system installed, i have never had this problem till recently i hear a very loud rattle from underneath the car when idling. I have checked the resonator and it is still good i dont know what it could be..... Heat Sheild???? its drivin me crazy!
Old Feb 28, 2008 | 03:26 AM
NMgokart's Avatar
NMgokart
Your exhaust may have loosened up or shifted in it's mounts and is close enough to a heat shield to produce the rattle. Also check your right front motor mount for leakage; if the engine is sagging there, it will throw off exhaust alignment too. Best of luck !
Old Feb 28, 2008 | 06:08 AM
edijak's Avatar
edijak
Muffler Install
When I had the JCW tuning kit installed, I had significant rattles at certain RPM and over rough road. Back to the dealer we go. Dead center, where the cut is made to install a new muffler system, is a H shaped brace roughly 18"x 12", black, held on by 4 bolts. The JCW muffler rattled against this brace. Rather than make adjustments, the dealer took the brace off indicating that the muffler hangers were all that was required. I questioned that approach but, no more rattles. Check it out.
Old Feb 28, 2008 | 06:38 AM
quikmni's Avatar
quikmni
Double-check that it is not hitting in the back. When new, my Milltek rattled due to contact in the back and I had to adjust the rear hanger by adding a spacer (large nut) to create a little extra space. You can test by pushing on the exhaust in the rear to see if it hits. Maybe yours has shifted slightly to cause it to start rubbing.
Old Feb 28, 2008 | 09:19 AM
Lauren06's Avatar
Lauren06
When I had a milltek I had the same problem as quikmni. The system alone sits too high and close to the bumper and it rattles against the bumper at idle. Many have used washers to bring the hangers down some, you should try that.
Old Feb 28, 2008 | 11:00 AM
eager2own's Avatar
eager2own
Any other mods?
(specifically . . . USS?)
Old Feb 28, 2008 | 06:00 PM
herbie hind's Avatar
herbie hind
yes they do rattle . thank god for radios
Old Feb 28, 2008 | 11:47 PM
pepegrande008's Avatar
pepegrande008
Mine does too. especially after the fidanza flywheel and koni kit. Still tryin to figure all of them out. Does anyone else's control panel for the sunroof rattle? that one bugs me the most. also my interior door panel rattles when its cold
Old Mar 23, 2008 | 01:49 PM
thebestbear's Avatar
thebestbear
Deleted
Last edited by thebestbear; Mar 23, 2008 at 02:01 PM. Reason: went to wrong thread
Old Mar 23, 2008 | 03:13 PM
canyonking's Avatar
canyonking
yea, same problem hear, check your head shields, if your exhuast heats up and expands it can wiggle around it what little space it has, causing it to hit the underbelly of your car and heat shields, and it just so happens that the exhaust rattles at the same vibration as the car, making the sound only at idle, but moves faster when your moving or reving, making it less noticable......same thing happened with my borla....good luck
wildwestrider
Dec 27, 2015 08:20 PM
USA-RET
Nov 9, 2015 07:27 PM
embiggenedmini
Oct 15, 2015 12:36 PM
Sep 3, 2015 02:06 PM
