Cold start chatter
Old Apr 15, 2008 | 10:24 PM
  #651
MikeWz's Avatar
MikeWz
Try parking it on a slant for a long period if you can as well. If you've got ramps or something like that. I'm picking mine up next weekend, and I'll be parking on a driveway that's angled pretty well towards the rear wheels, so I'll get to see how that affects mine too
Old Apr 16, 2008 | 02:10 AM
  #652
rippymcs's Avatar
rippymcs
I don't have ramps and my garage is pretty flat, so I'm gonna try the flat position first and then do the simulated slant with jacks after that.
Old Apr 16, 2008 | 06:14 AM
  #653
tjtull's Avatar
tjtull
Originally Posted by rippymcs
Just an update. (reminder: I had the cold start chatter at 235 mile)
My car was parked for four days straight again (for the third time), and no chatter still (car is barely over 400 miles at this point). So we can completely rule out long term parking being one of the cause for the cold start chatter.
I'm going to try and test out the other theory this weekend, which is the short-engine-run theory, where the engine runs for less then a couple of minute prior to shutting it off and then park for extended time.
I just started mine after sitting for 5 days straight (in my garage). I have just over 1200 miles on it and have not yet changed the oil (but I will soon). I didn't get any clatter noise. I ran it for about 5 minutes and then shut it down. Temperatures at night here have been a little chilly, mid-30s range, for that time period.
Old Apr 16, 2008 | 11:43 AM
  #654
bitharvest's Avatar
bitharvest
my car just sat for 5 days, after a short drive (less than 3 miles), and when i started it this morning, no noise. temps were higher (in the mid 50's) than they have been, but i've had the noise even in that temp range...
mymini must know it is going in for a service appointment next week!
Old Apr 16, 2008 | 06:26 PM
  #655
rippymcs's Avatar
rippymcs
So I guess we can rule out short engine run as the culprit.
Today I went to the dealer to pickup my license plates, it was an hour drive round-trip. I also stopped for lunch at a place 5 miles away from my house. No unusual noise. When I got home and pulled into the garage, the typical "FSI noise" (sounds like valve tapping) was a bit louder than normal, but not to the point where it sounded like a diesel engine.
Old Apr 21, 2008 | 12:58 PM
  #656
brizio81's Avatar
brizio81
Please
check this site:
http://www.r56mcs.com
It's a dedicated site abt cold start issue, the site is ---new--- and there is ---no post yet--- but it's a good opportunity for a survey / poll about the chatter!
Anyone with a recent built MINi has experineced the prob again?
Old Apr 21, 2008 | 07:30 PM
  #657
r56mini's Avatar
r56mini
It's been in the 40°+. And after work when I start it it makes the abnormal noise everyday.
Old Apr 23, 2008 | 05:05 AM
  #658
korby's Avatar
korby
Interesting! From Mini 2
If the chain had stretched would this not mean you would hear the noise at least every cold start?
We are only talking 6-12 month old cars and nothing with excessive mileage.
How old were those Nissans?
Seem to affect lot of Nissans (micras, sentras, almeras)
Timing chain question [Archive] - Micra Sports Club
2007 Micra, timing chain/tensioner noise on starting engine - RAC Motoring Forum
"worked at Nissan for ten years and we have long experienced timing chain problems
The most common engines that sufferd from chain sretch were the almera and primera models (X99-54 plate) fitted with QG15 and QG18 engine.
The K11 model (1993-03) never sufferd from chain stretch (they just used to snap!)
The K12 micra (your model) is fitted with a nissan timing chain and we did have problems with the early K12 chains stretching, which causes loss of power (due to the ignition timing being out) and you may get the engine warning light on which usually flags up a fault with the camshaft position sensor, again this is due to the timing being out.
The noise on start up has been common on the micra since the first models from 1993. It is noticable more on cold mornings, as soon as the oil pump starts getting oil to the top of the engine the noise goes.
I would not be to concerned at the moment about you're car, I know they have fitted a modified chain on the later models so I wouldnt worry untill you notice running problems with the car and/or engine warning lights.
Make sure it is serviced every 9,000 miles or 12 months (whichever is sooner),
to keep ther warranty valid incase the chain needs attention in the future"
VCT problems also sound similar
brgc00perboyView Public ProfileSend a private message to brgc00perboyFind More Posts by brgc00perboyAdd brgc00perboy to Your Buddy List
Old Apr 23, 2008 | 05:12 AM
  #659
Loony2N's Avatar
Loony2N
I don't profess to be an expert, but it would seem to me, we are talking about VERY minor changes in parameters here. Things, especially metal, change size under different heat/humidity conditions. Thus, it would take the right circumstances for the noise to occur. Of course, the same applies to the oil itself.
Old Apr 23, 2008 | 09:20 PM
  #660
r56mini's Avatar
r56mini
It seems to me the chain tensioner gets stuck in the compressed position and takes time to expand. But some dealers already have replaced the tensioners and the problems came back. All I can say is it must be a design flaw. I will have to let the car go before the warranty is up.
Old Apr 23, 2008 | 09:26 PM
  #661
Bhatch's Avatar
Bhatch
Anyone have any issues related to this chain problem other then the noise?
Old Apr 23, 2008 | 09:59 PM
  #662
Benibiker's Avatar
Benibiker
Do Clubman owners also have the cold start clatter?
Old Apr 25, 2008 | 04:50 AM
  #663
cycleway4's Avatar
cycleway4
Hi...Have followed your posts here on the cold start noise on the MCS's....Is the base engine in the Cooper not effected?...I was thinking they were basically the same [engine] with exception of the turbo on the S?....
This may have been addressed somewhere and I overlooked it.
Steve
Old Apr 25, 2008 | 05:51 AM
  #664
russr's Avatar
russr
The base cooper is not affected. So the Clubman Cooper is not affected, but the Clubman S will be affected.
Old Apr 25, 2008 | 07:26 AM
  #665
chandler_vt's Avatar
chandler_vt
The bleeding procedure hasn't worked but it did resolve the issue temporarily.
So I m going to get them to do a full oil change. Or at least have them perform the procedure once again..
The noise is NOT completely random. It has do with how much the temperature changes (at least for cars sitting outside). If the temperature changes too much then I get the problem. If the difference is only 10 F then I dont see the problem.
Also driving short distances might be the issue too (I dont drive much and have just 4000 miles after 9 months of owning it)
Old Apr 25, 2008 | 08:55 AM
  #666
Ferroequine's Avatar
Ferroequine
They are the same block, but IIRC (with the R50/R53 anyway), on the 'S' engine all the internals are replaced with higher performance and stronger bits to handle the extra HP from the turbo/supercharger.
Old Apr 25, 2008 | 09:06 AM
  #667
cycleway4's Avatar
cycleway4
OK...thanks for the replies....was just curious why it effected one and not the other.
Old Apr 25, 2008 | 10:49 AM
  #668
ClubmanS's Avatar
ClubmanS
So no word from MINIUSA, yet?
Old Apr 25, 2008 | 07:26 PM
  #669
rippymcs's Avatar
rippymcs
My theory is that the issue is with the injectors; the chatter noise sounded like amplified injector noise. When I had the noise on my MCS, the noise was more prominent at the top of the block, and not at the side where the timing chain is. This theory is supported by the fact that only MCS, which has FSI, has the noise, and the regular Cooper does not. Again, this is just my theory.
Old Apr 27, 2008 | 08:55 AM
  #670
r56mini's Avatar
r56mini
I hope some engines go cahpoot! so all the S's can be recalled for a permanent fix or a refund.
Old Apr 27, 2008 | 11:48 AM
  #671
Dr Obnxs's Avatar
Dr Obnxs
Nope...
It has variable valve lift and different cams. The top of the engine is very different between the two...
Also, if it's just direct injection stuff, why would BMW be doing ANYTHING to the valve train? I think your theory needs some work.
Matt
Old Apr 27, 2008 | 05:52 PM
  #672
VelvetFoot's Avatar
VelvetFoot
I think it's some weird software thing and the timing/injection or something is very advanced. Yes, my theory also needs some work.
Old Apr 27, 2008 | 07:42 PM
  #673
rippymcs's Avatar
rippymcs
I've worked my theory down to mere speculation.
Old Apr 29, 2008 | 07:20 AM
  #674
chandler_vt
Guys
How many of you have a consistent rattle for more than 3-4 minutes? Mine goes away in a minute or 2 max.
I think the problem is with the cars where the rattle stays on for a really long time.
Old Apr 29, 2008 | 04:12 PM
  #675
Halifax's Avatar
Halifax
Originally Posted by chandler_vt
Guys
My '07 MCS (Nov. '07 build) had the noise once in Mid-March at about 2000 miles. It went away in about a minute. Hasn't happened since, but I am very concerned about this happening again. I do not understand MINI not addressing this concern ... what's up with that??
