Indirect TPMS not resetting
Old Feb 12, 2008 | 09:09 AM
jakay11's Avatar
jakay11
I have found a very slow leak in the L-Rear tire at the valve stem...
I usually fill up with gas and air every week, but last week I was away and the car sat, in a cold garage, all alone.... the L-rear was about 10psi low.
I got in, and sure enough the TPMS lit up shortly after I drive off to go get some air about 0.1mi away...
I check all pressures (reset them all to 38), reset the system per the owners' manual, but it doesn't...
I tried turning the car off and on again and followed the procedure.
TPMS is still glowing yellow.
I drive off to work (~50mi)... at about mi 25 it resets itself.
WTF?!
Anyone else run into this?
(The car is an '06 MCS, and I'm running 17" Enkie rims with Hakkas.
The tires will probably need to be replaced after this season due to wear.)
Old Feb 12, 2008 | 09:56 AM
mylittlemini's Avatar
mylittlemini
It sounds like George was angry with you for leaving him all cold and alone in the dark all week. That was just his welcome back.
I do know that with a indirect TMPS system you do have to drive a little bit so that the computer can relearn how fast the tires are rotating compared to each other. With my '05 it only takes about a couple blocks or about a minute to reset.
Old Feb 12, 2008 | 10:28 AM
SRICHS's Avatar
SRICHS
Just make sure that the TPM button doesn't get stuck. Usually that's the collection area for change, spilled coffee, and a spare set of gloves [either for shovelling or driving!]
Old Feb 12, 2008 | 10:34 AM
MININRG's Avatar
MININRG
TPMS
I have done the same thing. After I air up the tires up to the correct pressure. I get in turn the key to the on position with the TPMS button held in waiting for the light to go out. Nothing happens. I drive for two blocks then the dash dings at me and the light goes out.
Old Feb 12, 2008 | 03:26 PM
rhawth99's Avatar
rhawth99
Mine has always gone out quickly (a minute or so).
freckles81
Jan 15, 2017 06:33 AM
OldElvis
Tires, Wheels, & Brakes
Oct 1, 2015 06:21 AM
simo711
Sep 29, 2015 11:53 AM
PSU 98
Sep 11, 2015 11:20 AM
renchjeep
Sep 6, 2015 01:54 PM
