Seat Height Lever/Arm help.
Old Feb 6, 2008 | 06:58 AM
golden_child's Avatar
golden_child
Coordinator :: Capital Area MINI Modders
Did some searching but I can't seem to find the answer to my question.
Heres the story. I was getting out of the car yesterday and the bottom of my jeans got tangled up with the seat height lever. Yes I looked like an idiot when I almost fell over getting out of my car, felt like one too. Well, it looks like that I used just enough force to move the adjusting lever (4) out of place and pop the cover off (5). Everything works fine, goes up and down but is seems a bit loose. A little more wiggle than I previously remember. The base of the lever (round part connected to seat) doesn't sit flush against the seat base anymore either. I compared it to the passenger seat and it is definitely a little off.
My question is, can I remove the lever and see if I just need to adjust it and refit it with out springs and mechanical pieces exploding in front of me leaving the seat adjuster useless?
I've looked under the cover (4) and I see 3 screws that look like they hold the arm on.
Seat on realoem
Old Feb 6, 2008 | 09:29 AM
lotsie's Avatar
lotsie
Can you just try and re tighten the screws/bolts , rather than take it all apart. Although from the picture the lever attaches to the crank, which would have all the springs and such in it, so if need be you should be able to take just the handle off without things flying apart.
Mark
Old Feb 6, 2008 | 11:07 AM
golden_child
Mark
That's what I was hoping to do. I just wasn't positive if the mechanism itself was encased and the lever was separate. And, if the lever was separate I could remove it and realign/set it.
Old Apr 14, 2008 | 08:55 PM
Xbass's Avatar
Xbass
Same issue here...but I BROKE the lever getting out of the car today
What the heck!!!
I'll have to bring it in and have it replaced. I wish the lever was tighter to the seat.
Old Apr 15, 2008 | 06:24 AM
golden_child
The handle is separate from the gearing/lifting mechanism. So if you only need to replace the handle, you should be able just to purchase that part. You can pop the cover off the side and there are 3 screws (i think, 3) that hold the lever in place. Just back those out and install the new lever.
Old Apr 16, 2008 | 10:36 AM
Mr.x.'s Avatar
Mr.x.
hey... I have an extra handle left over from a seat repair if anyone wants it
Old Apr 16, 2008 | 02:29 PM
Xbass's Avatar
Xbass
PM Sent
Old Feb 20, 2010 | 07:32 AM
MiniMar3's Avatar
MiniMar3
How to "pop off" seat adjuster handle
I have a similiar need to remove the seat adjuster cover so I can get a
stuck seat belt out. When you say "Pop Off" the cover ... can I simply
place a flathead screw driver between the cover and the seat and pry it
off without cracking the cover, if I do it slowly?
Thank you!
Old Feb 20, 2010 | 11:00 AM
Cadenza's Avatar
Cadenza
What you've described is the exact vision Mini engineers envisioned when they designed the lever. British humor... humour!
I hit the damn thing almost every time I get in/out of the car. One day it will happen.
gsredmini
Oct 20, 2015 07:43 AM
please_remain_calm
R57 :: Cabrio Talk (2009+)
Sep 10, 2015 12:33 PM
Sterling Thompson
Sep 9, 2015 07:42 PM
SeattleF56
Sep 3, 2015 03:01 PM
