Rattles Thread
Old Feb 1, 2008 | 07:01 AM
  #26
Minidrivr's Avatar
Minidrivr
Originally Posted by LynnEl
Exactly and it really pisses me off that the dealers, who can easily fix the rattles, act like that is how the car should be. MINI is either the most inept or uncaring car company I have dealt with since the 70's. I have had this bucket of bolts almost a year and just yesterday I got a card in the mail from Mini saying "We heard you will soon have a new Mini." Jackasses.
I had the opposite experience. I was very surprised how good the attitude was towards me when I asked my dealer about some rattles. The tech even was asking if they were happening more when the car is cold or warm, offering to keep it overnight to make sure they found and fixed the rattle I was having.
I was prepared for getting the same response you got but only had a good experience.
Old Feb 5, 2008 | 10:21 AM
  #27
fjork_duf's Avatar
fjork_duf
Update: I still have the resonating/buzzing/rattle sound coming from inside my steering column. I was right. They were not able to cure the issue. I did however figure out what is causing it. If I adjust the wheel up and down there is no issue, but in a certain position toward the driver the sound will then happen when going over a concrete/rough road surface.
If I had to make a guess it probably is some wire or something else inside the column that bends in/out when the wheel is adjusted for reach. I think I could possibly fix it if I knew how to get the steering column cover off. I suspect you just pull it off with your hands, but I'm not sure if it's screwed on. Anyone pull off the plastic covering on the R56 steering column?
Old Feb 5, 2008 | 11:17 AM
  #28
Loony2N's Avatar
Loony2N
Just another example of the dealer not wanting to "waste it's time" fixing the problem, so they claim there isn't one.....
Old Feb 5, 2008 | 11:45 AM
  #29
fjork_duf's Avatar
fjork_duf
Just to be fair they did replace some switches and junk inside the column. But that didnt' fix the issue. But I must agree the overall service experience has not been that great although they did win me over at the end.
Old Feb 20, 2008 | 09:31 PM
  #30
checkercoop's Avatar
checkercoop
Well I just noticed 2 new rattles and buzzes.
The rattle I now notice in my door when I go over light bumps (its annoying because its right in my ear so music really can't cover it)
The buzz I noticed in my headliner right where the upper toggle switches are (again right in my ear)...this one i notice occurring from the engine vibrations around 2000 rpm
I'm going in on tue anyway for an engine whistle, now i think i will add the door rattle and have them fix the secret compartment (they had to fix my dash rattle, but now the secret compartment scrapes the left air vent)
I feel annoying sometimes, but I drive a lot without the radio so I need certain rattles to be fixed...i know not all will and i know cars make noise, but some are driving me crazy cuz they are in my ear no matter what
Old Feb 21, 2008 | 05:20 AM
  #31
GregO's Avatar
GregO
rattles???
Rattles??? C'mon! I don't need to be hearing about rattles yet to show up on my new mini. Don't want any rattles or any grinding gears, either! Fingers crossed.
Greg
Old Feb 23, 2008 | 07:11 PM
  #32
MontanaMini's Avatar
MontanaMini
I don't have a rattle, per se, but the one noise that drives me insane is a skittering/sliding noise somewhere up in my sunroof trim. It only happens when I take a turn, but even after feeling and looking all over the sill, I can't find anything loose that would cause the noise.
Old Jun 8, 2009 | 05:44 PM
  #33
Silvasurfa's Avatar
Silvasurfa
I have a 10" sub woofer in the boot. When the volume is cranked it makes something inside the hatch rattle...It's located right behind the license plate (no it's not the license plate rattling). This is only audible from outside of the car. Has anyone experienced this? I would like some insight before I start taking things apart.
Old Jun 8, 2009 | 06:49 PM
  #34
thevelourfog's Avatar
thevelourfog
I had a rattle from the steering column while accelerating between 2k and 2.2k rpms, quite annoying. I took it in twice and got the tach replaced the 2nd time, now all is good.
Old Jun 30, 2009 | 04:30 AM
  #35
johanvanderberg's Avatar
johanvanderberg
Originally Posted by lacning74
Here's a repost of a dash rattle fix.
I've been having this dash rattle in front of the speedo over bumpy roads. As tipped by Unixgal, I checked these screws since I had removed them in the past while installing my Kuda mount. They were on tight, but I noticed that the snap-out covers wiggled quite a bit so I left them off. No more rattle. Maybe I loosened these snap-out covers when I removed them before? Anyway, looks fine without them, so I'm not going to bother putting them back and figuring out how to secure them better.
Sad thing is I had a dream about doing this the night before.
Also, I fixed my rattling radar detector, the Escort 9500i, that was clipped to the headliner just to the left of the rear-view mirror. I lined the outside of the visor clip with the fuzzy-side of velcro tape to dampen its contact against the roof and windshield. I then put the hook-side of velcro on the top of my radar detector in front of the buttons. Now when it is clipped, it doesn't slide or bounce around.
Now, I am going to tackle my sunroof trim rattles with some foam tape.
I actually ordered these covers from MINI last week.... the torque screws without the cover clips bothered me... seeing the cut dash trim everytime I washed my car.... but also have this rattle since fitting the cover clips it sounds worse! What does these torque screws do...? I've tightened them but the rattle is still there. Mini replaced some clips for me about a month ago but I feel like going back asking them exactly what they replaced... has no one found a self fix for this problem yet....
Old Jun 30, 2009 | 07:53 AM
  #36
lacning74's Avatar
lacning74
drove me crazy too. i put em back on cuz i started getting the rattle back anyway. you can use some sticky tack maybe to hold the cover in place if it's really making things worse. the screws hold the speedo dash trim in place.
anyway, when my rattle came back, i ended up stuffing a diaper (unused) under the top dash behind the speedo to the edge of the windshield. i had the trim removed already as well as the speedo/stereo and i ended up removing a bunch more screws in order to lift up the top dash. it's worked so far for over an year. who needs dynamat when you got a pack of diapers in the trunk?
there have been a few dealer fix success stories for the upper dash or "behind the speedo" rattle. this thread has a SIM number as well. one guy required the speedo itself to be replaced as well as adding insulation behind it. doubt they used diapers though.
Old Jun 30, 2009 | 08:40 AM
  #37
johanvanderberg
diapers! thanx for the link, will need to buy torque drivers 1st as I borrowed someone's the last time I checked' what bugged me a little was how to redo the screws once you put the cover back on... they sit fairly deep and surely cannot be reached by hand to "guide" them in before tightening... after my last visit to mini I think it's best to fix these "niggles" yourself as I don't think they really care about rattles etc...
Old Jul 8, 2009 | 12:22 PM
  #38
SteelersFan's Avatar
SteelersFan
Originally Posted by misslindsey
...My hatch rattles sometimes - louder (of course) with the seats down. I haven't tried to find/fix that yet - there's a good chance it's just some random piece of crap I've left in the boot.
I finally fixed the boot rattle in both my cars:
https://www.northamericanmotoring.co...3-post825.html
Old Jul 8, 2009 | 12:45 PM
  #39
bssiesmth's Avatar
bssiesmth
1) Rattle on the dashboard, right at the point where the top of it is in contact with the A pillar. Solution: either push down really hard on that part while driving (kinda hard with a manual car) or insert a little plastic ball between the top of the dashboard and some structural member below it.
2) Odd rattle every now and then on the armrest.
3) very strange rattle on the trunk (or around it - perhaps it's something lose in there? I'm not carrying anything).
Solution to all the rattles: live with them. Everyday I seem to find a new one, so there's no point in agonizing over them. I think.
Old Jul 8, 2009 | 01:40 PM
  #40
Ottoman_FD3S's Avatar
Ottoman_FD3S
I don't have much rattling in my car except one in the headliner near the light switches inside the little domething somewhere.. i can stop it when i push up on it with my hand...
bass in the car sometimes brings out rattles in the rear hatch and side rear panels.. but not alot..
what I do get is alot of creaking from the plastic.. when the chassis flexes and torques the plastics squeak as they rub against each other... quite annoying cuz a)it sounds awful and b) makes me wheel the car is "flimsy" and "loose" even tho it's not
Old Sep 4, 2009 | 10:41 AM
  #41
minimanmini's Avatar
minimanmini
Strange rattle in the rear on the drivers side i think.
I have pulled everything out in the back and put the seats down as well as tried taping the latch on the hatch back cover. ive pulled seat headrests off as well
ive emptied the repair kit in the boot as well.
dealership has adjusted the rear sway bar fittings as well.
when driving it sounds like a high pitched rattle like two pieces of metal cicking together. i really think it is in the hatch and if i open the back door and drive slowly over a few bumps or even close to 50km the noise is no longer there. any ideas?
Old Sep 4, 2009 | 06:38 PM
  #42
RJKimbell's Avatar
RJKimbell
Molly has had what we hope to be one of the last Rattles fixed today at Rasmussen. The rattle was in the Secret Compartment Door, you'd push on it and the rattle would go away. From the RO here is what the Tech found and fixed:
"Test drove verified rattle noise from CD Compartment Door, removed trim, used Felt Tape to insulate area, Test Drove, No further rattles pressent from CD Compartment Area at this time."
They also performed a Sun Roof Fix, you'll find those details in the "Sun Roof does not open when it's warm out..." Thread.
Old Sep 5, 2009 | 07:53 AM
  #43
SteelersFan
It may be what I finally fixed. Did you see post 38 above ^? Good luck.
Old Sep 5, 2009 | 11:48 PM
  #44
Ottoman_FD3S
Just like to update my own post
I left for a 1 month holiday and parked my car in the garage
come back after the holiday
and now I have rattles inside both of my doors or there abouts
wth??
Old Sep 6, 2009 | 05:36 AM
  #45
ronnie948's Avatar
ronnie948
Passenger Seat belt "DUH!!!"
I had a rattle this morning. First one in over 5,000 miles. It was the metal push hook on the passenger seat belt rattling against the side piller.
NO MORE RATTLE
Ronnie948
Old Sep 12, 2009 | 11:03 AM
  #46
rrcaniglia's Avatar
rrcaniglia
Dealer just found my 2-3k buzz that seemed to be coming from inside the dash around the steering column. It was, in fact, coming from a plastic plate to the right of the gas pedal. It is removed with a T-20 TORX head. Dealer says there is another plastic part immediately behind. Buzz was solved with a piece of 'foam' double-sided tape that was used as single-sided tape so as to not bind the two pieces together. Drove 2 hrs back from dealer and it was still working when I reentered city traffic at this end.
Three cheers for MINI of Nashville (Gary Gray-SA) for taking the time to find what was a fairly minor issue--and doing it without an appointment. (I was there to have a side scuttle replaced.)
Old Sep 12, 2009 | 11:29 AM
  #47
Benibiker's Avatar
Benibiker
Originally Posted by Bishamon
I have one that I believe I have narrowed down to the passenger seat, since it doesn't rattle when there is a passenger in the car, and it seems to only return the day after someone has been sitting there (i.e. the rattle won't be there for a while after the passenger has left).
I have a rattle on the passenger seat too... It keeps rattling away about incoherent subjects while I'm trying to enjoy the drive. Seems to go away when the seat is vacated.
Old Sep 12, 2009 | 09:23 PM
  #48
RJKimbell's Avatar
RJKimbell
Yeah...somtimes I wish my Husband had a MUTE Button too!!
Old Sep 13, 2009 | 12:54 AM
  #49
skimmilk's Avatar
skimmilk
I have a rattle with the silver plastic part behind the window switches. It feels like theres some tape without enough adhesive... if I "push" it in, sometimes the sound stops for a while.
Old Sep 13, 2009 | 01:52 AM
  #50
MINIxB's Avatar
MINIxB
I have a rolling sounds in my boot when I take a turn sometimes or take a bump at an angle... Also have a rattle coming from the passenger side somewhere but I think it's the seatbelt and i'm not too worried about it.
