Flat tire monitor -- False alarm?
Old Jul 7, 2003 | 06:20 PM
mpemburn's Avatar
mpemburn
We took a trip to the shore this weekend -- a couple of hours each way. About an hour into the trip, a little chime sounded and the Flat Tire Monitor started flashing. We pulled off to check the tires and saw nothing wrong.
At the first opportunity, we stopped at a service station and checked the pressure. The right rear seemed a bit low so I topped it up and reset the monitor, following the directions in the manual. The light went out and stayed out the rest of the trip over and didn't make a peep on the trip home.
Today, I got about 20 minutes from home on the highway and the same thing happened. This time, there was no pressure difference in any of the tires. I reset it and it happened a third time within a couple of miles (this time on surface roads). I tried calling the local MINI dealer service department for advice but was not able to get through to anyone (this in itself has me worried).
I noticed a couple of mentions of both the Tire Monitor and DSC lights registering false states at the same time but I don't think there was anything in the 'search' that matched my exact symptoms. Anybody else had this happen?
Old Jul 7, 2003 | 08:00 PM
Luthier's Avatar
Luthier
I had the same experience, but only once.
At that time, I increased pressure to 33psi from 31psi and right next day the warning light came on. I drove whole day with warning light, but once I exactly followed the instruction of the manual and reset the flat tire monitor, it worked fine.
As the manual says, I pushed the button long enough to reset it.
Mine would not be a good reference for you, but I guess sensitivity of the sensor might be the issue...
Old Jul 8, 2003 | 11:33 AM
mpemburn's Avatar
mpemburn
Thanks Luthier. I drove a couple of hours today at highway speeds and on surface roads and the monitor didn't come on. Maybe just a fluke.
BTW: Are you, as your handle suggests, one who builds and/or repairs stringed instruments? I've always been fascinated by this and may take it up as a retirement hobby/business. The most I've done so far is set up my electrics (pretty easy) and a little fret re-crowning. All with the help of the redoubtable Dan Erlewine's book.
Old Jul 10, 2003 | 06:14 PM
mpemburn's Avatar
mpemburn
Update: Not a fluke -- a genuine flat tire caused by one very large staple. The monitor was jus' doin' its job.
Old Aug 7, 2003 | 01:53 PM
BradBJ's Avatar
BradBJ
I had my runflat monitor go off once and it was due to driving on a muddy road.
Brad
Old Sep 8, 2003 | 03:38 AM
Gidget's Avatar
Gidget
i've had this happen 3 times now. I stopped and checked all tires, checked pressure and it was at 32-33 all around. I tried to reset, didnt' work, then it went out. Stayed off for a long time and then the other day it happened to turn on again -- i'd say 2 months later. Im going to have it checked when i get the boot latch replaced.
just annoying and kinda freaks me out since i know how much one tire will cost to replace :|
Old Sep 8, 2003 | 10:14 AM
jdw5155's Avatar
jdw5155
The system does work pretty well even though it doesn't have a pressure sensor.
I've had occasions when passing over water/snow/ice with one side of the car. Since it detects the wheels rotating at a different speed the light will come on in error.
I've also had one occassion where the light came on while driving on dry highway pavement. I'm glad I pulled over right away. I could still hear the air hissing out of the tire near the nail. After getting towed we were able to salvage the tire with a simple plug. WAY better and cheaper than driving a few miles on the runflat sidewalls which typically requires that you replace the tire.
Regards,
Jim
Old Sep 8, 2003 | 10:25 AM
Thechandler81's Avatar
Thechandler81
Funny subject, I just got a flat tire today.
I had a slow leak from a nail in the middle of the tread, and the Flat Tire light did come on. I checked, and found the problem, so the light does work for that purpose.
For false alarms, I have had it happen twice. once on a very cold day (0 deg. f) And another from driving on a bumpy, wet road very fast.
Waszak
Oct 21, 2017 05:55 PM
molala
Oct 2, 2015 01:53 PM
jesterofatlas
Sep 4, 2015 11:23 PM
Sep 3, 2015 10:45 AM
Ntety
Sep 2, 2015 08:39 PM
