fuel guage
Old Nov 16, 2007 | 03:11 PM
ryansoxfan's Avatar
ryansoxfan
fuel guage
I just filled my car up two days ago. Today as I was driving it I noticed the fuel guage showed that I had less than a quarter of tank. My trip odometer shows that I have only driven 80 miles since filling up. Could there be a problem with my guage? I have looked around and can not see or smell any fuel leaks. Does anyone have any ideas what could be going on? Any suggestions are appreciated.
Old Nov 16, 2007 | 03:12 PM
joey1320's Avatar
joey1320
the meassuring sending unit is faulty. are you under warranty?
Old Nov 16, 2007 | 03:33 PM
ryansoxfan's Avatar
ryansoxfan
not under warranty. is this an expensive part to replace? is it possible to do on my own? or should i leave that to the pros?? thanks.
Old Nov 16, 2007 | 03:39 PM
lawmann's Avatar
lawmann
Coordinator :: Middle Georgia MINIs
If you are no longer under warranty I would buy the Bently Manual for MINI. What a FANTASTIC shop manual to have. If you are mechanically inclined you should be anle to do the work. Just be sure to empty that fuel tank a bit, it can be heavy!
Also, be sure to follow all the good and common sense precautions when working with gasoline!
Old Nov 16, 2007 | 03:41 PM
Eric_Rowland's Avatar
Eric_Rowland
First, give it a while and see if it 'wakes up'. This issue has been seldomly reported here on NAM.
The sender(s?) are in the fuel tank, so it wouldn't be a fun job.
Old Nov 16, 2007 | 04:29 PM
ryansoxfan's Avatar
ryansoxfan
just took it for a spin and i started tapping the guage (like a movie pilot when his fuel runs out) and surprisingly it started going up. is there a way i can test the sending unit? i'm sure that was the problem and it looks like it still needs to be replaced.
Old Nov 17, 2007 | 01:53 PM
joey1320's Avatar
joey1320
you can test the resistance on the sending unit inside the tank. i would rec. getting the service manual and looking it up for proper values. the fuel pump and sending unit are under the rear seat. i can't recall which of the 2 sides is the sending unit on.
is a pita to do the sending unit since you have 2(or was it 3) tubes that must go from one side of the tank to the othr(to the pump) and is a hassle. just takes times and patience.
good luck!
IQRaceworks
53
Jun 28, 2024 07:29 AM
OutMotoring
Mar 3, 2017 06:29 AM
wildwestrider
11
Jan 29, 2016 05:06 PM
HK_MCS
R58 :: Coupé Talk (2012+)
Oct 4, 2015 08:03 PM
dutchhome
Sep 30, 2015 07:17 AM
