Moisture "steam" coming from Vents
Old Nov 14, 2007 | 09:55 AM
MiniS AZ's Avatar
MiniS AZ
I am getting what i can call moisture "steam" coming from vents. It's intermittent, seems to happen when i turn the AC. Has anyone else had this issue?
I recently have topped off my coolant. Could I have overfilled and this is the cause, sorta a mystery!
Is it safe to drive as long as i keep the antifreeze level up?
Old Nov 14, 2007 | 01:14 PM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
A momentary 'fog' coming from the a/c vents when first turning the system on is normal. It will happen in rare cases of cooler weather with humid conditions. Adding engine coolant has no bearing on this, even if you add too much.
Now, if you feel 'steam' coming from the vents, and if using your defroster coats the windshield with a fog that needs to be wiped off (meaning, it does not evaporate soon after the system has been on), this indicated a leaking heater core. If this is the case, and your coolant has been disappearing requiring you to top it off, look for coolant stains on the carpet in the footwells.
Most likely (and hopefully) it's the first diagnosis.
Old Nov 16, 2007 | 12:18 PM
MiniS AZ's Avatar
MiniS AZ
Unfortunately, It's #2. Luckily I am still under warrenty (for another 2,500 miles). I have a puddle on my drivers side floor. Where is it coming from? I can't tell.
triple5soul
21
Jul 29, 2016 04:27 AM
wkp1219
Nov 13, 2015 07:52 AM
Shane Wendel
Aug 21, 2015 01:04 PM
fjork_duf
Tires, Wheels, & Brakes
Aug 16, 2015 04:38 PM
kwijmbo
Aug 5, 2015 09:00 PM
