cooling fan problem?
Old Oct 25, 2007 | 08:03 AM
edgab's Avatar
edgab
i've tried to search my problem here but found nothing related...
i've read that our cooling fan operate at two speeds (low and high). but ever since i got my r53 in 2004, it seems to be operating only at low speed... and never did it turn on when my engine's off (i've read that sometimes it turns on to cool the engine)... we are in a tropical country btw. any problem with my cooling fan?
Old Oct 25, 2007 | 08:17 AM
kapps's Avatar
kapps
Your fan shouldn't come on with the engine off unless you did some hard driving then immediately shut down. It's only happened to me once and that was when I had air in the system after changing my coolant. As for low/high, it's hard to explain. When it's on high, it's very easy to hear. Low speed usually comes on a couple seconds after you click the A/C on.
Old Oct 25, 2007 | 10:43 AM
lotsie's Avatar
lotsie
My 03 Cooper rarely comes on even after shutting it down after spirited motoring. It does come on when the A/C is running.
It did come on high when coolant dumped when the block heater failed, not an issue for you as you live in a warm climate. It sounds like a jet engine when it does come on high
Mark
Old Oct 25, 2007 | 10:41 PM
edgab's Avatar
edgab
thanks for the replies! i recently noticed that the hi low speeds are working... but not that hi compared to other mcs' here.. hmm.. and will try driving it hard then turn off the engine.. will try to see if the fan will work.. thanks!
iggi
18
Feb 9, 2026 01:00 AM
alistaircookie
Oct 8, 2015 10:52 AM
danielbrookes_9
Oct 3, 2015 12:51 PM
Manny_cooper
Sep 10, 2015 11:09 AM
David.R53
Sep 1, 2015 06:51 PM
