hesitation at startup
Old Jun 26, 2003 | 12:55 PM
emobob's Avatar
emobob
I believe this has been talked about in previous months, but I've recently started having the problem.
When I start the car the first time for the day, it doesnt want to go anywhere. I have to rev rather high and keep it there while initially moving. If I dont do this the mini really starts to lug and drag (I would just call this really bad hesitation). It dissappears rather fast.
Whats the deal with this?
Old Jun 26, 2003 | 01:02 PM
dominicminicoopers's Avatar
dominicminicoopers
Sounds like either your clutch is slipping or, you're slipping your clutch.
Old Jun 26, 2003 | 01:08 PM
emobob's Avatar
emobob
Neither, its definitely an engine issue.
Besides, if it was clutch related it wouldn't go away.
Maybe I just didn't explain it well enough, I dunno.
When I start to go forward in a normal manner (after just starting the car), the car will lurch, like under heave engine breaking all of the sudden. and it takes a few high reves to get it to start responding like normal.
Does that make more sense?
Old Jun 26, 2003 | 01:14 PM
dominicminicoopers
Yes, that sounds different.
The first description of the problem sounded more like the clutch didn't fully engage even though the pedal was all the way out (slipping) until the clutch assembly built up some heat, then mechanically it made it's connection.
Your second description sounds more like an engine management issue than clutch.
emobob's Avatar
emobob
also, it is a october build. and the AC is not on (I never have to use it thanks to the tint and the sunroof, even in florida!)
Pker
Apr 11, 2017 12:14 AM
Jerome R Jr W
Sep 29, 2015 11:42 AM
jennster
Sep 28, 2015 06:19 PM
kjd186
Sep 9, 2015 10:02 AM
Sep 8, 2015 11:37 AM
