passenger side motor mount
Old Oct 30, 2007 | 12:52 PM
  #26
muggy's Avatar
muggy
I assume it's something better. When I brought my car in for service at 12k they changed it without me asking for it, I think MINI knows it's a faulty part.
Old Nov 2, 2007 | 04:41 PM
  #27
Funk_Flex's Avatar
Funk_Flex
I got mine today even though my car was in service for something else.
Recently I've been hearing a faint knocking sound from the engine. I instantly thought bad engine mount. But I didn't noticed any fluid on the mount itself. So I just thought it was something else. But I guess the tech who worked on my car noticed the noise when he drove off in my car .
Thank goodness I turned off the radio when I got to the dealership.
Old Nov 3, 2007 | 03:10 PM
  #28
PmP's Avatar
PmP
Mines gone at 49,000 miles feb 04 mcs. Out of warranty, so duno if they will change it free or not, doubt it. gettin it done in 1000miles at service. Is this ok for 1000 miles?
Old Feb 23, 2008 | 09:11 PM
  #29
Gil-galad's Avatar
Gil-galad
So I was washing all of the wintertime sludge off the garage floor today and noticed some darker stains in the MINI's spot that would not scrub up for anything. Finally had to resort to WD-40 and steel wool to get it up. Getting suspicious, I popped the bonnet to take a look and...
...YUK
According to the odo indicator, I've only got 975 miles until my next scheduled maintenance (~27K total). What are the odds that the dealer will go ahead and do the maintenance check if I bring it in for the mount replacement?
Old Feb 23, 2008 | 09:27 PM
  #30
LordOfTheFlies's Avatar
LordOfTheFlies
My dealer will do the maintenance as long as the counter is within 1000 miles....I would just call 'em up and ask.....
Old Feb 23, 2008 | 09:31 PM
  #31
Gil-galad's Avatar
Gil-galad
Thanks for the info. I hope Motorwerks in Minneapolis is equally accommodating.
Old Feb 25, 2008 | 08:48 AM
  #32
gaffer's Avatar
gaffer
'05 R-50 CVT here. Motor mount leaked out @ under 10,000 miles! Replaced under warranty.
Old Feb 29, 2008 | 08:03 AM
  #33
AstroBlackS's Avatar
AstroBlackS
Originally Posted by Deviant
Is there any aftermarket part to replace this with that's not fluid filled or at least doesn't fail quite as easily? I figure while under warranty it's not such a problem but once out of warranty if this fails I only want to have to deal with it once.
+1
I'd like to replace that setup with something solid. Poly is fine with me, as I don't mind the vibrations.
I'm looking at this...
http://www.vipcustomparts.com/minicooperparts.htm
Old Feb 29, 2008 | 03:17 PM
  #34
rhawth99's Avatar
rhawth99
My wife's '05 MCSa just puked all over the garage floor (just under 25K miles). I have it scheduled for this coming Wednesday to leave at the dealer. My '06 MCS had the mount replaced around 21K. Hope the replacement parts are better!
Old Feb 29, 2008 | 04:03 PM
  #35
Gil-galad's Avatar
Gil-galad
Mine was just replaced today (under warranty ). Not sure if the guts have been redesigned, but the outer casing looks identical to the original part.
Now comes the fun of trying to clean up the leftover mess. I played around a bit with some WD-40, but it looks like it's going to take some time and elbow grease to get through the stained PW paint just below the mount. It may be a lost cause...
Old Mar 1, 2008 | 09:18 AM
  #36
SteveS's Avatar
SteveS
I wanna put a bracket under the nut which goes up through the damper/engine support on my 2003 MCS. How do I get the nut to loosen? Do I have to take the wheel liner off and is there a hex head bolt to grip or is the bolt connected to the damper?
Old Mar 2, 2008 | 08:32 AM
  #37
MiniMacster's Avatar
MiniMacster
I am experiencing a knocking that is not consistent. It appears when the weather is cold, and the engine is cold. Also more in 2nd gear. It does not change with either road speed or engine speed. It goes away when the weather warms up (50-55 degrees or more), and when the engine warms up. Does this sound familiar to anyone with the motor mount failure?
Old Mar 5, 2008 | 01:46 PM
  #38
wildcrazy442000's Avatar
wildcrazy442000
My Right Motor Mount just threw-up, 17.5K on a R50.
Old Mar 5, 2008 | 03:22 PM
  #39
Scooby03's Avatar
Scooby03
I keep several of these in stock, as they go out often. Glad I have an 03.
Old Apr 10, 2008 | 11:43 PM
  #40
Spencer J's Avatar
Spencer J
Motor Mount just replaced
Same Motor Mount is being replaced on my new (just a few days old to me) 06 JCW.
Old Apr 11, 2008 | 12:13 AM
  #41
ScottRiqui's Avatar
ScottRiqui
And to add to the confusion, I think MINI has re-designed the "new-style" mount at least once. My wife and I both have mid-to-late year 2006 models, and we haven't had any problems after about 30k miles on each car.
So, it's possible that if you have the mount replaced, the replacement may well last the life of the car. I do know that while I've heard of a bunch of people having to have the mounts replaced, I haven't heard many people that have had to have them replaced *twice*. (I know LOTF is doing his second replacement now, but since his first replacement was done 2+ years ago, I don't know if it would have been replaced with the redesigned mount or not.)
I guess an interesting thing to track would be how many 2007/2008 convertible owners are having to replace mounts, since they would almost certainly have gotten the redesigned units at the factory.
sevin
May 2, 2026 06:11 AM
DixonL2
Apr 13, 2021 08:05 AM
boostedhaze
Jan 2, 2018 07:26 PM
polotska
Aug 23, 2015 03:03 PM
JPMontes3
Aug 23, 2015 01:26 AM
