Bonnet Heat/Deformed Scoop
Old Sep 27, 2007 | 08:08 PM
  #26
Jinxy's Avatar
Jinxy
01' V6 Maxima I've seen as high as 140F on a 95F day. You don't jerk you hand off the hood like you do on an '07 MCS. You can keep you hand on the hood as you think, "that's pretty warm".
On my '07 MCSm, you touch the bonnet area around the scoop, then jerk your hand back and say, "Holy cr@p, that's hot as s#1t... someone could suffer a serious burn from this".
Then you think "where's that IR thermometer I got for Xmas last year". Then you start checking temps all over the Mini's bonnet, the spouses hood, the neighbors hood...
So far my Mini is in first place with highest boonet temps of any car I've measured.
Old Sep 28, 2007 | 06:14 AM
  #27
Jinxy's Avatar
Jinxy
Anyone know how to get MiniDivision to respond to questions??
Old Sep 28, 2007 | 06:24 AM
  #28
korby's Avatar
korby
Sometimes they lurk in 2nd generation stock problems / issues I've only seen them respond to wind noises though .
Old Sep 28, 2007 | 07:13 AM
  #29
Jinxy's Avatar
Jinxy
Opening the scoop does help a little, but I don't think it's the correct solution. I started a thread in the 07 Coupe Talk similar to this one. I've asked NAM to move it under the Stock Problems/Issues.
Here's the link: https://www.northamericanmotoring.co....php?p=1775896
Old Sep 28, 2007 | 07:21 AM
  #30
Jinxy's Avatar
Jinxy
There's also another thread where bonnet temps are mentioned, along with the driver side A-pillar getting toasty warm as well.
https://www.northamericanmotoring.co...d.php?t=112726
I hear MiniDivision lurks around this forum. I would love to hear from them regarding these two issues. I'm more concerned about the extreme bonnet temps then the A-pillar being warm.
Old Sep 28, 2007 | 08:09 AM
  #31
Jinxy's Avatar
Jinxy
Thanks korby, I've asked the NAM admin to move this to Stock Problems/Issues.
Old Sep 28, 2007 | 10:13 AM
  #32
korby's Avatar
korby
OK I got my MT-exp Micro Temp Digital Infrared Thermometer $49.95 at Pep Boys !
Temps taken after 30 mile normal drive ,never over 4000 RPM s
hottest spot on Bonnet -203 F
Under Bonnet
Turbo - 276 F
Plastic Coolant Reservoir - 195 F
Tail Pipe after 10 min. -a cool 127 F
Hot spots next to gas pedal 110 F that surprised me !
Old Sep 28, 2007 | 10:22 AM
  #33
korby's Avatar
korby
Ok I posted temps on the other thread ,Hottest spot on bonnet after 30 min. normal driving not over 4000 RPM s -203 F !
Old Sep 28, 2007 | 10:28 AM
  #34
TheBigNewt's Avatar
TheBigNewt
I remember Arnbut doing the thermometer thing a month or 2 ago. He had a thread here and Mini2 as well. He contacted Mini NA, etc. Did the footwell temps. As I recall they told him that's the way it's built, it's hot but we can't change anything, see ya later bye bye.
Old Sep 28, 2007 | 10:44 AM
  #35
korby's Avatar
korby
Just made a pot of coffee ,poured into cup and shot it ,142 F .My son tells me water boils at 212 F ,real close to bonnet temp .
Old Sep 28, 2007 | 11:04 AM
  #36
uzun's Avatar
uzun
Has anyone thought about placing a sticker like this on their bonnet to warn others?
http://www.cafepress.com/buy/hot/-/p...t_/pg_/c_/fpt_
Old Sep 28, 2007 | 11:06 AM
  #37
Birdman's Avatar
Birdman
Has anyone made or no where to purchase a "bonnet bbq grill" attachment?
203 F would be perfect for grilling!! The angle/incline of the bonnet would make it work exactly like the George Foreman gill, all the grease would run right off making a perfect, healthy MINI-Burger!!!
Old Sep 28, 2007 | 11:16 AM
  #38
Jinxy's Avatar
Jinxy
Originally Posted by Coffeeman
Agreed...I would venture to guess that at least one of us would be told by MINI "Gee this is the first complaint we've received, regarding this".
The tech told me he wasn't aware of the A-pillar heat issue and that turbo hoods get really hot. He said he would contact Mini to see if any other reported the issues.
He got back with me a few days later and said Mini doesn't have a fix for either issue at this point. I don't know if that means they are aware of it or not... or willing to acknowledge it.
I filed a safety complaint with NHTSA regarding the bonnet temps. 235F seemed excessive to me. I suggest all '07 MCS owners also report the issue as well.
The NAM user MiniDivision has yet to reply to my request for information regarding the excessive bonnet temps.
Their response is usually:
I'm with MINI USA. I've passed this message on to a MINI National Customer Relations Representative who will be in touch with you soon.
I wish we could get them to reply.
Come on MiniDivision! Give us a response please.
Old Sep 28, 2007 | 11:30 AM
  #39
Jinxy's Avatar
Jinxy
Arnbut had his 07 MCSm (manual) replaced with a MCSa (auto/CVT). He said the new one runs cooler (140ish). That's most likely due to the CVT transmission cooler requireing the fan and/or water pump to run longer after parked. In addition to the hot bonnet issue, his MSCm had a multitude of other issues as well.
Old Sep 28, 2007 | 01:16 PM
  #40
daffodildeb's Avatar
daffodildeb
Okay, I put mine in. I used "Structure: Body: Hood" as the component, and listed "1" as the mileage of "failure." Unfortunately this complaint form is designed for a single incident, so it may not get picked up. I did reference "temperatures well over 200 degrees" in my complaint.
Last edited by daffodildeb; Sep 29, 2007 at 09:26 AM. Reason: Correction--"mileage" instead of "date"
Old Sep 28, 2007 | 01:20 PM
  #41
daffodildeb
This engine would be ideal for cooking on. If you think I'm kidding, I'm not--there is a whole book (can't remember the title) on cooking on car and truck engines, with food wrapped in foil. I actually tried this on vacation a couple of years ago, but it didn't work well due to the configuration and lack of heat in our rental van. Bet it would be different in the MINI, though.
Old Sep 28, 2007 | 01:23 PM
  #42
Modnar's Avatar
Modnar
FYI, the R56 has a 6-speed auto. They ditched the CVT.
Old Sep 28, 2007 | 03:51 PM
  #43
MotorMouth's Avatar
MotorMouth
Charcoal for dinner anyone?
Old Sep 28, 2007 | 04:58 PM
  #44
Modnar's Avatar
Modnar
'Now you're cookin' with turbo!'
Old Sep 28, 2007 | 05:43 PM
  #45
aem421's Avatar
aem421
Jinxy,
Where did you buy your car? I noticed that you Ordered 6/29 -- Delivered 8/1. I ordered mine from Tate on 6/30 and picked it up on 8/31. My hood does not get hot at all. My WRX hood got way hotter than my MCS. I drive 30 minutes to work everyday. Hood never gets hot. Do you have the holes in your scoop like I do? Makes a huge difference.
There's no way I can burn my leg on the tail pipes. They don't stick out far enough. Take a look...
Old Sep 28, 2007 | 05:45 PM
  #46
minicobra1's Avatar
minicobra1
I wonder if un-corking the fake hood scoop would help lower engine compartment temps. I've seen somewhere on here where people have made or are making the hood scoop functional in hopes of increasing HP, but it may be a better benifit in just keeping overall engine bay temps down. Anyone on here have there hood scoop functional and try measuring temps?
Old Sep 28, 2007 | 06:00 PM
  #47
amazonracer's Avatar
amazonracer
I have a MCS Auto and I drove a ton today. I felt my bonnet after I got home and it wasn't hot at all. The funny thing is that when I first got the car in July I felt the hood because of these concerns and it was very hot as I recall. But not this time. Any thoughts.
Old Sep 28, 2007 | 06:08 PM
  #48
korby's Avatar
korby
Feel the gap above the scoop !
Old Sep 28, 2007 | 06:28 PM
  #49
FugitiveAI's Avatar
FugitiveAI
Though I haven't felt heat like any of you are describing, I'm popping out the partially vented grille in the scoop when I install the Alta CAI I have on order. I definitely recommend doing it. It certainly shouldn't hurt anything. You can always dremel out some or all of the blocked vent parts if you prefer to keep the grille in. As for the original question in this thread, I'm very curious about this as well. I wish they published a rev log for the ECU software.
Old Sep 29, 2007 | 05:12 AM
  #50
Jinxy's Avatar
Jinxy
Great! Thanks daffodildb.
