weird notifications.
Old Sep 15, 2007 | 11:48 AM
heyjay1428's Avatar
heyjay1428
got my 07 mcs in about march, and i've been driving it for a while, an within the last few months, the brake light (red on the small computer screen -whcih means to change out brake pads / braking flud (if yellow), asc (the thing next to the sports button (yellow triangle with the circle around it), and the tire has low pressure.
didn't know hwo to chagne this, maybe i need to fix all 3 of those...but the signs come and go.
or if it's just a computer problem.
help please!
Old Sep 15, 2007 | 06:09 PM
MotorMouth's Avatar
MotorMouth
Do a search for "SZL". Do your blinkers and windshield wipers act funny sometimes?
Old Sep 16, 2007 | 12:20 AM
heyjay1428's Avatar
heyjay1428
nope, it's just the asc, flat tire, and the red brake sign that comes on.
Old Sep 16, 2007 | 07:37 AM
djam43's Avatar
djam43
Same thing happened to me one time, but never repeated itself.
Old Sep 17, 2007 | 07:41 PM
heyjay1428's Avatar
heyjay1428
BUMP
Old Sep 17, 2007 | 07:43 PM
heyjay1428's Avatar
heyjay1428
Old Sep 28, 2007 | 03:25 PM
heyjay1428's Avatar
heyjay1428
POSTED PIC OF MY PROBLEM.
BUMP DE HUMP! comes and goes.
anyone know why?
Old Sep 29, 2007 | 08:24 PM
dwdyer's Avatar
dwdyer
This looks like the Steering Angle Sensor (SZL) problem to me. Do you find that the turn signals don't shut off automatically after you go around a corner when this is happening?
Old Oct 4, 2007 | 07:04 AM
dbhouston's Avatar
dbhouston
Mine started doing the exact same thing yesterday. The two warning lights come on and the blinkers won't turn themselves off automatically. I'm calling my dealer today.
Has anyone been able to fix this issue before?
Old Oct 4, 2007 | 05:49 PM
MotorMouth's Avatar
MotorMouth
DB - your problem sounds like the SZL.
heyjay, if your blinkers work correctly you may have a bad ground.
check these two ground locations located under your drivers side wheel well:
edit:
I just had a look and I think those two are directly beside your fuse box under the bonnet. Look outboard and down from your fuse box and you'll see two ground wires attached to the chassis. Make sure the nuts are tight
Old Oct 6, 2007 | 02:04 PM
heyjay1428's Avatar
heyjay1428
hhahaha thanks! will do, sorry i hvaen't replied recently was internet-less but will check these. thanks!
Old Oct 7, 2007 | 08:11 PM
heyjay1428's Avatar
heyjay1428
well i went to my thing and found it. its quite down there. i couldn't get my hand threw it but by the looks of it, it seemed like it was loose. could it be anything else?
Old Oct 7, 2007 | 08:47 PM
MotorMouth's Avatar
MotorMouth
It might be something else, but if it is loose I'd bet that is the problem.
Get a rachet with an extension to reach it.
Old Oct 8, 2007 | 03:48 AM
glangford's Avatar
glangford
edit:
Where did you get the 3-D image??
Old Oct 8, 2007 | 05:02 PM
chiki143's Avatar
chiki143
Those are the exact same warnings Scarlett displayed this morning. Turning her off and on again, they remained. Seems its the SZL sensor or body control module that is faulty and needs replacing.
JHolland
Sep 24, 2020 08:20 AM
rt808
Sep 29, 2015 03:15 PM
Miniwaukee
Sep 29, 2015 09:22 AM
whowantstorace
Sep 27, 2015 06:16 PM
rt808
Sep 25, 2015 01:59 PM
