ScanGauge, codes, help me help myself
Old Sep 6, 2007 | 09:51 PM
karlInSanDiego's Avatar
karlInSanDiego
I installed a rear sway bar and shortly thereafter I've consistenly gotten what I refer to as the holy trinity of warning lights. Brakes, then ASC, and finally Flat Tire. I'm guessing it's a problem with a rear wheel sensor (used for ABS & flat tire sensor), but I'd like to determine which side is out without guessing and replacing one. I purchased a Scangauge, but it shows no code, even though the car now gives me the Trinity right at startup.
Can anyone give insight about making Scangauge look harder, or assuming that this is not an OBDII code, does anyone know a command to send to the ECU to get the ECU to let me know what's going on. Or alternatively, anyone know how to easily determine which side's hosed. I suppose my next step will be to ask the dealer to read check for codes.
Old Sep 7, 2007 | 09:04 AM
rataha's Avatar
rataha
I don't think you will have any codes. Replace the wheel speed sensors and your life should go back to normal
Old Oct 16, 2007 | 12:54 AM
karlInSanDiego
Wanted to follow up. Took it to dealer. They pulled all 4 wheels and inspected brakes. Decided it was LOW BRAKE FLUID due to pad wear. Instead of showing a brake fluid light or a single brake icon, you get the Disney light show. So be warned, when your brakes wear, you'll likely get this triple warning.
Old Oct 16, 2007 | 10:21 AM
pastabatman's Avatar
pastabatman
Thanks very much for letting us know the outcome. Geez, that sure wins the grand prize for 'unintuitive diagnostic'. Is that documented somewhere, at least for the service departments? I'm bookmarking this thread.
Old Oct 17, 2007 | 12:47 PM
th3118's Avatar
th3118
Coordinator :: Dynamic MiNi Collective
How many miles are on your Mini?
Steffen.Johnson
71
Jan 26, 2021 09:11 AM
shorenetworks
Nov 4, 2019 06:18 PM
olson187
Sep 18, 2015 10:26 AM
Mini Hooper
Sep 17, 2015 01:58 PM
