Oil like substance leaking onto front bumper
Old Aug 2, 2007 | 06:15 PM
ramtaajogi's Avatar
ramtaajogi
I just got my car 2 week ago and saw some oil like sustance leaking onto my front bumber. I opened my hood and took some pictures of where the stuff was coming from. Looks like some type of lube. Is this a problem? or just something that happens.
i uploaded my pictures to flickr. thanks for your help.
the pictures are from the underside of the hood in case you cant tell.
http://www.flickr.com/photos/25622707@N00/
Old Aug 2, 2007 | 06:23 PM
masterd78's Avatar
masterd78
MANIAC
I have read about some sort of coating to prevent the ocean salt from ruinning the paint. And when it gets hot it starts to drip like that. Anyone with experience is this what that is? I don't have mine yet, but would like to know what to look for when she comes.
Old Aug 2, 2007 | 06:26 PM
SNEEEZY - Erika's Avatar
SNEEEZY - Erika
Rattle Can Queen!!!
That's exactly what it is...it's called cosmolene.
Old Aug 2, 2007 | 06:27 PM
SNEEEZY - Erika
Rattle Can Queen!!!
It's cosmolene and it's easy to clean up.
How many Orandas do you have?
Old Aug 2, 2007 | 06:29 PM
ramtaajogi's Avatar
ramtaajogi
i have 2 orandas and 2 ranchu's. they are getting big fast.
Old Sep 12, 2007 | 10:43 AM
saoralba's Avatar
saoralba
What would be a good product to clean this with. I have tried several times whilst washing it and it still leaves a stain on the trim
Old Sep 12, 2007 | 03:30 PM
ramtaajogi's Avatar
ramtaajogi
i was able to just wipe it clean
Old Sep 12, 2007 | 04:21 PM
Capt_bj's Avatar
Capt_bj
Wd-40 on a clean rag .... apply "wax" after
Old Sep 12, 2007 | 05:00 PM
dwdyer's Avatar
dwdyer
Read on another board that Zymöl makes something called Strik that will remove cosmolene. It is an "engine cleaner" but they say it's safe for painted surfaces. You might try bug & tar remover too.
Old Sep 12, 2007 | 09:15 PM
Xray'dit_Mini's Avatar
Xray'dit_Mini
The dealer uses Kerosene to remove the Cosmoline.....
I feel Capt_bj was correct in saying that DW-40 would probably do the trick. I use it to get tar and other like substances off the paint.
Old Sep 12, 2007 | 09:24 PM
jw34's Avatar
jw34
Apparently the orange goo stuff and peanut butter work too.
Old Sep 13, 2007 | 05:15 AM
saoralba's Avatar
saoralba
Thanks for the advice. I'll see what works. I was able to get it off the paint but it had left a stain on the black wheel arch moulding, hopefully one of these tips works.
Old Sep 13, 2007 | 07:59 AM
Capt_bj's Avatar
Capt_bj
lil secret
lil secret - WD-40 is essentially kerosene in a spray can .....
Old Sep 13, 2007 | 10:46 AM
Tharkun's Avatar
Tharkun
I used Simple Green and worked well.
Old Sep 13, 2007 | 01:18 PM
ExpatBiker's Avatar
ExpatBiker
if i were you i'd be MUCH more worried about the pink fish swimming in your radiator fluid. fish poop will eventually clog your coolant system.
Old Sep 14, 2007 | 11:44 AM
brownsworth's Avatar
brownsworth
I had the same thing happen to me when i got my car about a month ago. It was coming from under the hood and leaking out onto the wheel arch at the top of the front wheels. I just wiped it off with a rag before I washed the car.
Old Sep 14, 2007 | 12:24 PM
mattbren
My MCS just sat on the dealer's lot for two weeks waiting for a part to come in and when I got it back yesterday, it had large streaks of cosmolene running down the plastic trim. The service manager told me that if left on, it would stain the trim permanently. She said they've been trying to get Mini USA to do something about it but they've told her it's only a regional issue in the Southeast and they don't intend on changing their use of the cosmolene.
Anyway, i've tried peanut butter (didn't work), bug and tar remover (didn't work), and now WD-40 (this took the remaining material off but there are still streaks evident after it dried.
Any other suggestions on how to remove the streaks? Does the cosmolene react with the plastic in a way that really is permanent?
Old Oct 27, 2007 | 11:01 AM
gokartride's Avatar
gokartride
I think it does unless you really keep cleaning traces off until it's gone. I'd talk to your SA and have the affected pieces replaced. Seems to me thats the only known cure when the staining is bad.
I chased this stuff all summer and was able to keep it from ruining the wheel arches on my car, but at the moment I'm driving a poor MINI loaner that no one has cared for. I'm quite sure if they ever try to sell it they will replace the trim which has swollen in the places where the cosmolene has leaked. We, as owners, deserve no less.
Old Oct 27, 2007 | 11:04 AM
r56mini's Avatar
r56mini
I used both simple green and turtle liquid polish on it. Not together at the same time but one after the other. Mine came off.
Old Aug 30, 2009 | 07:32 PM
Benibiker's Avatar
Benibiker
Japanese cars come on ships too and you don't see cosmoline all over their cars to prevent corrosion. What's their secret?
Old Aug 30, 2009 | 08:33 PM
rwwilsonjr's Avatar
rwwilsonjr
Dripping "Cosmoline" has been a problem much discussed on this fourm. It is a corrosion preventative coating applied prior to shipping. The idea is for the stuff to be removed at the POI or at the dealership (the customer shouldn't have to do this). Obviously they don't do a great job of cleaning the cosmoline and so some of the stuff remains on the vehicle after delivery to the customer. So when the car gets hot enough (sitting out in the summer sun) the cosmoline becomes molten and flows out of its nooks and crannies (sometimes onto the plastic trim).
It is fairly easily removed from the painted sheet-metal but (if it dries) it is not easily removed from the textured plastic trim. The key is to make sure you remove it from the trim before it dries. If it dries then all bets are off...it can discolor the trim. Also if you use a harsh chemical to remove it from the trim you can end up doing further damage. Here is one link (there are others):
https://www.northamericanmotoring.co...ml#post2443907
Old Sep 8, 2009 | 04:28 PM
AT T 2D's Avatar
AT T 2D
Our dealership recommended Dawn dish washing soap which worked well.
Old Sep 8, 2009 | 07:47 PM
RJKimbell's Avatar
RJKimbell
Using a solution of 50/50 Simple Green and water can remove the Cosmoline drip from the Wheel Arches. A discoloration is not that difficult to remove simply use a Good Plastic Protectant (Black Wow, etc.), make several passes and continue to apply until the stain is gone.
Using Dawn may get the Cosmoline off of where ever it is, but it will also leave your paint unprotected. Dawn removes all polishes and waxes from your paint, if you choose to use Dawn you must be sure and re-wax your car otherwise any other contaminents that come in contact with the paint will be much more difficult to remove. It is also recommended that you use a Clay Bar on your paint after using Dawn followed by waxes and polishes.
Etrain
16
Aug 5, 2024 04:37 AM
FLYM1N1
Aug 15, 2015 11:20 AM
smlzilla
Aug 14, 2015 07:00 PM
JHolland
Aug 13, 2015 10:47 PM
skippermini
Aug 12, 2015 10:05 PM
