re-emerging RUST
Old May 21, 2007 | 02:56 PM
jksgoh's Avatar
jksgoh
re-emerging RUST
Hi guys,
I've read quite a bit on the whole rust problem with the minis, but havn't been able to find anything on reemerging rust after it has been fixed (if there is a thread could some one link it to me?)
Anyway, this has what has happened:
Brought my car in januaryish to get the rust on the door sills fixed, they approved it and did it all under warranty. came back looking fine.
4-5 months down the track, i look again under the rubber door sill and what do you know, rust has appeared again! has anyone else had this problem of reemerging rust?
I was wondering are the rubber sills meant to keep water in or out? because when i lift the sills up water flows out (both before and after it was replaced when i had the rust fixed).
Also, if the car is properly galvanised what is the reasoning for it to rust ? Should it not prevent corrosion even in a damp environment (ie under the wet door sill)??
Old May 21, 2007 | 03:09 PM
caminifan's Avatar
caminifan
Originally Posted by jksgoh
...Brought my car in januaryish to get the rust on the door sills fixed, they approved it and did it all under warranty. came back looking fine. 4-5 months down the track, i look again under the rubber door sill and what do you know, rust has appeared again! has anyone else had this problem of reemerging rust?
Sounds like the rust was not properly neutralized. You have to use something like dilute phosphoric acid to neutralize the rust at a molecular level. Sounds like a return trip to the dealer is in order.
...Also, if the car is properly galvanised what is the reasoning for it to rust ? Should it not prevent corrosion even in a damp environment (ie under the wet door sill)??
I am not aware that the car is galvanized (properly or improperly). The car just has a corrosion warranty. Obviously, there are anti-corrosion steps that have been taken during the manufacturing of the car. But galvanizing? You may be expecting a bit too much. Galvanizing will not absolutely prevent corrosion - slow it down, but not prevent it.
PsychoRallye
21
Feb 17, 2019 06:08 AM
ronn
23
Sep 5, 2017 10:36 AM
Scm68
Jan 27, 2016 12:33 PM
minieater
Oct 28, 2015 02:15 PM
unxpectederror
Oct 22, 2015 12:16 PM
