Sin City MINI Club (SCMC) The forum of the Sin City MINI Club. Visit the club site at www.SinCityMINIClub.com
Driving Light and horn install help
Old May 28, 2008 | 11:30 PM
Sin MINI's Avatar
Sin MINI
Hey folks, I need to install the wiring harness for my Alta/IPF lights (light bar already installed), and besides my basic ineptitude, there are a couple of challenging parts I would like help with:
1) Can't figure out how to breach the firewall. I've seen all the posts and read all the descriptions, but I still can't see how to get there from here
2) No sure about the right wire (power to brights) to power the relay. I could buy a multimeter but not having used one in 20+ years I'm sure I'd mess that up !
3) I want to replace the stock switch with toggle switches...it will require cutting the old ones off and properly connecting the new ones, as well as running lines under the center console to the side mirror adjustment panel that will of course require modification...
The second part is that I want to install an "oogah" horn on a separate switch (not connected to the the OEM horn). I think I got this but I'm a little fuzzy on relays, not to mention the same issue as #1 above (breaching the firewall), kind of why I'd like to do these at the same time.
I am looking for someone willing to help me (I'll bring the beer!), or at the very least recommend a local shop that I could take this to and not feel ripped off. The IPF harness and installation description are top notch, professional products...but when it comes to this kind of stuff, well I'm not !
Thanks!
Old May 29, 2008 | 03:30 PM
Agro's Avatar
Agro
Coordinator :: Sin City MINI Club & AMVIV
Breaching the firewall is easy...you have a drill, right?
I can loan you a multimeter if it comes to that, but my experience with wiring harnesses is pretty much non-existent.
And I have no recommendations to make. You might try calling Jeff D and asking him for input.
Old May 29, 2008 | 03:51 PM
Stu's Avatar
Stu
I can't help you in anyway, shape or form. Well, other than helping you drink the beers you want to give away. However, where can I get copy of that KU badge? I know someone who would love it! She has a Jayhawk on the back of her current car - not sure if it will make it to the MINI or not....
Old May 29, 2008 | 09:52 PM
Sin MINI's Avatar
Sin MINI
I snagged a screen capture from the KU bookstore...it was an item for sale.
I'm going to He77 for sure!
Old May 29, 2008 | 10:49 PM
COR BLMY's Avatar
COR BLMY
you dont need a drill to breech the F wall
Just a sharp wire and push through the BIG rubber gasket at just above the sterring rod
Wrap your wire around that and pull it through
Old May 29, 2008 | 11:17 PM
Sin MINI's Avatar
Sin MINI
I know the gasket you're talking about, but I could barely see it, let alone get to it. I'll take another look. Thanks
PS: as for the drill, I'm pretty sure Andrew was kidding...
Old Jun 19, 2008 | 12:54 PM
Agro's Avatar
Agro
If you didn't buy your oogah horn yet, I got a coupon for one in an email from Harbor Freight this week. Let me know and I'll forward it to you (if I didn't delete it yet).
Old Jun 19, 2008 | 02:58 PM
Sin MINI's Avatar
Sin MINI
That would be great...was going to pull the trigger at there parking lot sale but had to rush out of town for a funeral and missed it.
Perfect timing ...
Old Jun 19, 2008 | 05:21 PM
xqb3b's Avatar
xqb3b
You can also breach the firewall from behind the battery. If you remove the battery, there are gromets there... just push through. Only problem is the confined working space.
Old Jun 19, 2008 | 05:27 PM
cartar452's Avatar
cartar452
Pretty sure he has a MCS.
Old Jun 19, 2008 | 07:46 PM
Agro's Avatar
Agro
I emailed you a link before I left work. $10 for a 12V oooga (their spelling) horn seems entirely reasonable.
If anyone else is near a Harbor Freight, here is the coupon link
Yes, Sin MINI has his battery located at the rear of the car.
Old Jun 19, 2008 | 10:20 PM
Sin MINI's Avatar
Sin MINI
Picked one up this afternoon. Thanks!
Old Jun 21, 2008 | 12:57 PM
Sin MINI's Avatar
Sin MINI
Is there a gap or do I need to punch a new hole through the gromit?
Old Oct 20, 2008 | 07:24 PM
GatorS's Avatar
GatorS
I've been thinking about buying one of those cheap but hopefully loud plastic truck horns...or rather a pair of them. I was wondering the best way to wire them into the stock horns so that all the horns go at once. Any suggestions on how to wire them and where to put them?
Old Oct 20, 2008 | 07:56 PM
COR BLMY's Avatar
COR BLMY
Yes ... punch a hole ...
The rubber will just about "seal" it back around the wire.
saftey wire or even a coat hanger (and a buddy) is the easiest combo.
If you peel the gromit back and put a wire between the gromit and firewall it has a chance of rubbing through the insulation
Old Oct 20, 2008 | 11:50 PM
Sin MINI's Avatar
Sin MINI
Thanks...I probably should have posted earlier that I was done with this mod
But thanks for jumping in!
Wohnson89
Jun 10, 2020 04:53 AM
ryGuyMCS
Oct 20, 2015 02:24 PM
Zettinger
Aug 25, 2015 04:04 PM
