Old 02-16-2017, 12:00 PM
Haag75's Avatar
Haag75
Haag75 is offline
Finished up the steel supports for my front spiltter. And just ordered a Sneed4Speed rear wing for the added rear down force. Should see that later this week. Getting ready for this up coming race season.
  #18527
Old 02-16-2017, 12:26 PM
HasAnMTBProblem's Avatar
HasAnMTBProblem
HasAnMTBProblem is offline
Are you doing turnbuckles on the splitter? How will you adjust it?
Also, this is pretty serious modding! Are you legit racing it?
  #18528
Old 02-16-2017, 12:34 PM
MiniRoadstah's Avatar
MiniRoadstah
MiniRoadstah is offline
Haag75... Wow, that's some serious splitter.
  #18529
Old 02-16-2017, 12:42 PM
Haag75's Avatar
Haag75
Haag75 is offline
Right now it is set dead flat to the ride of the chassis. There are a couple of brackets that I built that mount to the frame behind the core support that can be adjusted up or down to change the angle of attack. The ride height is exactly 3" with my 17" wheels and 2.5" with my 15" wheels.
And yes I do race wheel to wheel in NASA. It lost the ability to legally drive on the street years ago, so it is strictly a track car. I do miss my drives up the canyons though.
  #18530
Old 02-17-2017, 06:23 AM
sdiver's Avatar
sdiver
sdiver is offline
Today, all I could do is look longingly at my Clubman in the garage. For the past week she's been resting on jack stands, without any struts or shocks, while I impatiently await delivery of some KW Variant 2 coilovers from Way Motor Works.
Last weekend, I replaced the OEM rear sway bar with a Hotchkis 25mm Competition rear sway bar, and also replaced the lower rear control arms with a set of adjustable ones from Hotchkis.
  #18531
Old 02-17-2017, 07:03 AM
burley's Avatar
burley
burley is offline
Pulled the K&N intake from my '05 JCW and installed the stock JCW with an Amsoil filter. The hesitation on the WOT from idle (with gulping sound) is gone. This happened on all of my R53s as well with aftermarket intakes.. you get more supercharger wine, but I wonder if the performance is actually worse.
  #18532
Old 02-17-2017, 08:36 AM
HasAnMTBProblem
Awesome!
  #18533
Old 02-17-2017, 08:40 AM
MiniRoadstah
Might be an intake tuning resonance thing?
  #18534
Old 02-19-2017, 03:29 PM
Loyal242's Avatar
Loyal242
Loyal242 is offline
Switched to my summer wheel set.
No sense using the snows when it's 60 degrees out!
  #18535
Old 02-19-2017, 05:37 PM
MiniRoadstah
Brave. Hopefully an early Spring.
  #18536
Old 02-20-2017, 09:15 AM
MiniRoadstah
Decided to do some garage cleaning on Saturday, since it was relatively mild outside. Backed the Roadster out and noticed I should maybe take some pictures before our snow decides to go away. It's the second deepest snow cover we've had in 22 years here at this house.
Depth got to 43" on our snow stake the end of last 14" snow storm on Wednesday-Thursday. The most we've had on the ground at the snow stake was 48", back in the late 1990s. The Roadster's parked in front an area where I had to blow some snow off the driveway due to the wind... the other side of the driveway is where I normally stash the snow, and it's piled up a tad more.
The pics are not retouched and in color but they are crappy phone pics under cloudy conditions. And don't try the telephoto like on the first shot below. Even using a little still makes the picture grainy...
After I put the Mini away, the sun tried break out, so got it back out on the driveway for an attempt at a brighter picture... you can almost see a shadow, but not much brighter than the others...
Really hoping the roads dry out this week, so I can do some errands I've been saving up and get in some top down driving. Supposed to get to the upper 40s by Wednesday.
Is it Spring yet?
  #18537
Old 02-22-2017, 03:15 AM
Mini_Vinnie's Avatar
Mini_Vinnie
Mini_Vinnie is offline
Installed the awesome CravenSpeed short throw shifter!
  #18538
Old 02-22-2017, 07:28 AM
CooperSAZ is offline
Is it Spring yet?
Wow, looks great! Mini looks sharp with or without the sun! Always love the pics with the Mini and the snow.
  #18539
Old 02-22-2017, 10:15 AM
MiniRoadstah
Thanks! Have lost about 15" of the depth already in less than a week and it's almost 50 degrees today.
  #18540
Old 02-22-2017, 10:56 AM
Oh geez... is the 50-deg normal for this time of year? Or a little on the warm side?
  #18541
Old 02-22-2017, 03:22 PM
Bernard Barbour's Avatar
Bernard Barbour
Bernard Barbour is offline
Finally got around to replacing the bulbs in the driving lights. Was much more of a job than I thought and found a bunch of rust in the driving light housing. Just going to have to toss them and replace the whole light now. Have you checked your driving lights laterly?
  #18542
Old 02-22-2017, 06:21 PM
MiniRoadstah
A lot on the warm side for this day. Hit 52 this afternoon. Normal high would be 31 today. We seem to jump briefly in and then back out of Winter pretty often. We had 3 or 4 days that stayed about 10 degrees lower than normal a week ago while we got a couple of good snow storms.
Sketchy Winter weather has been happening for quite a few years up this way. At least we accumulated some good snow for a change. We'll see if we can keep some snow on the ground into March this year. Would be nice.
  #18543
Old 02-22-2017, 06:53 PM
MiniRoadstah
After you replace your lights, to keep the rust away, try turning on the lights at the end of your drive, especially if you've been thru rain, drizzle or fog. Heat from the bulbs will dry out the moisture and should help keep that rust from forming.
  #18544
Old 02-23-2017, 05:26 AM
Received 1,988 Likes on 1,785 Posts
I have seen that on very old lights / high miles. Yes getting the moisture out after a driving in the rain, also the caps help divert water if you don't use the lights that often.
Part # 63120137303 for the whole light housing, the cap is part # 63120144065
https://www.northamericanmotoring.co...s-oem-hel.html
  #18545
Old 02-23-2017, 01:24 PM
burley's Avatar
burley
burley is offline
Adjusted windows
Finally got around to adjusting the passenger window in my R52, which would leak at car washes. There was a little more than a fingernail gap that was driving me crazy. After ordering 2 adjustment tools, I finally found one that works.
Rotate the gears clockwise to loosen, unlike what I've read in threads here.
Check out this set on ebay. Is the rusted part the bowl that reflects the light or is there another bowl that bolts on?
http://www.ebay.com/itm/2002-2008-Mi...JYk7GV&vxp=mtr
  #18546
Old 02-24-2017, 05:01 AM
drewstermalloy's Avatar
drewstermalloy
drewstermalloy is offline
Last night I put the ALTA BOV spring replacement in. Today my coilovers come. Tomorrow I should be able to finish the rear suspension. 22mm rear sway bar, coilovers, lower control arms and end links.
All I need now is some fresh rubber for my new 949 6ul wheels.
  #18547
Old 02-24-2017, 07:43 AM
Bernard Barbour
Good job burley. I'm OCD too especially on windows and the like.
The inner housing was all rusted inside. The light bolts up fine and I can by with just replacing the bulb for now, but in a few weeks I'll order the lights from ECS.
Hey ECS thanks a bunch for directing me to the PDF files on the lights. Much appreciated.
  #18548
Old 02-24-2017, 07:52 AM
Welcome.
The back window on the R52 can be a pain, i have adjusted mine also with that tool: 83300494251 Window Regulator Nut Wrench
https://www.northamericanmotoring.co...tor-parts.html
  #18549
Old 02-25-2017, 02:35 AM
Anakist's Avatar
Anakist
Anakist is offline
Fixed my trio of warning lights - ABS, ASC and tyre pressure. It is a new hub and new sensor and I couldn't find any faults in the wiring. The metal seal ring had fallen out of the bearing and was rattling around on the axle boot. No idea how it happened but I cleaned the gunk off the inside of the wheel bearing and tapped it back in with a mallet and all fixed!
Now to make a tensioner tool to swap in my 15% pulley!
James
  #18550
Old 02-26-2017, 09:32 AM
Paul S.'s Avatar
Paul S.
Paul S. is offline
installed the Mini Sport Antennae some weeks ago
Quick Reply: What did you do to your mini today?
