H Stock My first time with slicks on the mini
Old Jan 23, 2008 | 05:23 AM
JBgotM's Avatar
JBgotM
I have autocrossed the mini 3 times on the stock all season tires just for fun, and finally have a set of holeys and old slicks to play with. The tires are A3S03 and pretty heat cycled. It was a fairly cold day here in FL and it was in the upper 30's during my heat. I started off with a split in pressure to have the back rotate. What I forgot about was that I could heat up the front tires much more quickly on that first run than the back.
After launching and going down the front slalom, I hit the brakes and turned in for the chicane. The car immediately swapped ends and had me facing the wrong direction. I finished the run and lowered the pressure a little.
On the second run I was a little more careful in the chicane, (but it was still a little slippery in the back) and got through decently, then spun the car in a similar situation towards the end of the run.:impatient
After that, I dropped all 4 tires to 30psi, fronts were reasonably warm and rears were cold. I thought this would correct the problem. Thankfully, I was right. The next 4 runs were better balanced, but the rear still stepped out a couple times only to be saved by turning into it and going WOT and staying aggressive.
Each time got quicker as I started to learn how to drive a FWD car on slicks (I'm used to a RWD SM2 car). I still have a long way to go to understand what the car wants for inputs and how to get the most out. We had 6 runs and in the end I thought I put up a respectable time, but was unsure if it was good enough to win the class. There were 4 of us in HS and one was a well-driven Mazda 3.
The Mazda ended up taking me by 0.23 on a 58.0 second course. I ended up 12th pax out of 57.
Not too bad for my first time on old slicks with this car, but I still have a lot to learn in meshing with this car.
Old Jan 23, 2008 | 05:56 AM
Motoring's Avatar
Motoring
Your handling problems are mostly related to old dead tires. they are unpredictable. As soon as you can get a new set, and you will be amazed at the improvement in performance.
With new tires start over with pressures, I ran in the mid 40's front and rear. Any lower in the front and Hoosiers will cord in a few runs. Kumho V710 will put up with lower pressure for longer.
Old Jan 23, 2008 | 10:25 AM
JBgotM's Avatar
JBgotM
I can see longevity wise that 40's would help, but grip is better as well? I would have thought you might be crowning the tires a little and reducing grip in the mid-40s.
Have you run the V710s on your car? What pressures did you settle on for a paved (and concrete) course?
Old Jan 23, 2008 | 01:49 PM
Motoring's Avatar
Motoring
I haven't run on the 15's in quite a while (Mid 05). but I ran the 215/40/16s at 45 front and 42 rear. I think I ran similar pressure in the 15's. I ran the same pressure for all surfaces, with some variance for air temp.
At lower pressure the tires develop a groove (groove of death) that seems to be from the tread surface flexing under g loads.
Old Jan 24, 2008 | 05:33 AM
JBgotM's Avatar
JBgotM
Thanks for the starting point of pressures.
I know I should really buy some new tires, but I am so cheap I hate buying slicks. I have been running used slicks on my SM2 M Roadster for a couple years now. I suppose if I was going to take it to a Tour or go to Naitonals, I would pony up a set. The last couple years I have been driving someone else's car at a couple Tours.
tr3y003
Oct 22, 2015 10:48 AM
Dashdog
Aug 10, 2015 06:17 AM
tippin
Aug 5, 2015 08:43 AM
