RSR Motorsports Coverage The forum for discussions related to RSR Motorsports campagin in the Grand Am Cup.
Daytona Test Weekend
Old Jan 12, 2010 | 08:12 PM
  #51
minimarks's Avatar
minimarks
We're not unhappy with Mini/BMW, we just want to see you and the RSR MINIS on the podium Randy! Which me thinks will happen this year!!!!
Old Jan 12, 2010 | 09:21 PM
  #52
Rsstopper's Avatar
Rsstopper
Coordinator :: RSR Motorsports Forum
Thanks for the support!
Randy
Old Jan 13, 2010 | 06:00 AM
  #53
RED FURY's Avatar
RED FURY
Originally Posted by newbs49
Nice pics Phil. Did you go down there?
Not since last May, when I drove on the track for time trials ... In a Mustang GT. When you whip around on the banked corners, you can't see squat, just pavement in front of you, you get sucked down, then the track flatens a bit as you come onto the straight, and then you can see .. it is weird.
The infield is fairly easy to negotiate, no big deal, just breaking into turn 1 is key
I spun after locking up a rear wheel, going into the kink on the back straight, no ABS at the time, flat spotted the tire bad, well no harm 'cept a 500$ tire gone bad !!!
I found those pics by searching ... I seeks, I find ..LOL
Old Jan 13, 2010 | 06:06 AM
  #54
RED FURY's Avatar
RED FURY
Randy
I posted some pics of the 2 cars on track but don't see the yellow one ... Is that a spare ? The cars look great and the times are sweet for that aero track
With front wheel drive and rain always a threat, we may have a great run
Do you find you can pass on the inside on the infield track ?
We will be cheering you all on !!!
Phil
Old Jan 13, 2010 | 06:29 AM
  #55
Rsstopper's Avatar
Rsstopper
Phil
The 198 (yellow) is now the spare car. It has been updated to all the 2010 spec's so it may a make an appearance or two later in the year.
The Mini's are the best in the infield. The strong lap times are a result of our speed there. We are also the best at the bus stop. The flatout aero sections (which is the majority of the track ) are our weak spot. The field for this year's event will be +/- 70 cars. In years past it has been +100. The smaller field should work to our advantage as the infield traffic will be less.
We left the test with a top three time (2:10.148 Owen 196) for the weekend so we can run up front.
On the other hand . . . it was REALLY cold and the Minis' like cold air. . . but then, most cars do.
We were pleased with the test
Randy
Old Jan 13, 2010 | 08:46 AM
  #56
Paul Webster's Avatar
Paul Webster
I was surprised that one of the Honda's went a 2.09 but even more surprised that they went a 2.08.599 in 2009 when I looked at last years results.
Good luck at the end of the month and make sure its 1-2 on the podium, I'm sure this vid at 2.00 will fire you and the other drivers / crew to make it happen
Old Jan 13, 2010 | 08:55 AM
  #57
Revolution Mini Works's Avatar
so you actually think everyone showed all of their cards?
Old Jan 13, 2010 | 01:47 PM
  #58
MaitlandImports's Avatar
MaitlandImports
HAHA, he had a tow from a Mustang GS car all the way around the banking... Correct me if I'm wrong but don't the Mustang GT's get the 5.4L motor? How is a lowly Civic able to hold close enough to a GS car around the banking to pick up a tow all the way around?
Old Jan 13, 2010 | 01:52 PM
  #59
newbs49's Avatar
newbs49
I thought everyone let it all hang out in testing sessions.
Old Jan 13, 2010 | 02:07 PM
  #60
minimarks's Avatar
minimarks
You guy's crack me up....
Old Jan 13, 2010 | 06:04 PM
  #61
only drag racers
Old Jan 13, 2010 | 06:14 PM
  #62
newbs49's Avatar
newbs49
Old Jan 13, 2010 | 11:06 PM
  #63
Paul Webster
The above two posts shows your lack of common sense.
Old Jan 14, 2010 | 07:29 AM
  #64
Rsstopper's Avatar
Rsstopper
They use a special 5.0 'cammer' Ford racing engine. High torque, 4 valve overhead cam.
Old Jan 14, 2010 | 07:39 AM
  #65
Rsstopper's Avatar
Rsstopper
1) Everyone claims they got a tow when they post a fast lap There is no way an ST car holds a tow with a Mustang at Daytona. . . unless it's a very slow one.
2) This is the first real event of the year so the track is not 'rubbered in'. I suspect the times will drop when the race arrives. The track conditions were unpredictable . . . including ice on Saturday morning. I don't tink anyone ran as as fast a time as they could have . . . nor as fast as they will come race day.
-R-
Old Jan 14, 2010 | 08:00 AM
  #66
newbs49's Avatar
newbs49
Ice cold tracks and sticky R compounds don't make for fast times. Hoping weather is better the end of the month, but not too hot for those intercoolers.
Old Jan 14, 2010 | 08:44 AM
  #67
MaitlandImports
Sweet spot I've found seems to be high 40's and Direct sunlight to warm the pavement up.
Old Jan 14, 2010 | 09:03 AM
  #68
newbs49's Avatar
newbs49
If anyone know's that track it would be you Ian living down there.
Old Jan 14, 2010 | 09:16 AM
  #69
MaitlandImports
You'd be surprised daytona is pricey and only a couple races there a year though SCCA. I don't have all that much time on it. I think I've done 3 races there + the One Lap of America Last May.
debitsandcredits
Sep 21, 2015 08:34 AM
KristaMcCoy
Sep 12, 2015 05:37 PM
Richard Kellstrom
Sep 4, 2015 07:21 PM
