AC Relay confusion
Old Jun 17, 2019 | 06:03 PM
evelluser's Avatar
evelluser
AC Relay confusion
I own a 2011 Countryman S All4. I recently returned from overseas and started driving my car again. My wife did occasionally drive my car while I was gone, but didn't use the AC as it was cooler out before I returned. I've taken my car to a shop and they did what they could and discovered I had the correct amount of coolant and no leaks, but the compressor clutch won't engage. The clutch is not locked up, as it will spin by hand but not when I try to use the AC with the car running. I did testing with my multimeter to try and diagnose electrical issues. I disconnected the black and yellow connector on the side of the compressor and tested the harness side connector to check for power and continuity. I can get a power reading, but no continuity signals; meaning on V DC i can read 14.5 volts, but on OHM resistance, there is no change and no beep (yes my multimeter has that function). Would this mean the relay is bad on the switch side and needs replaced?
If so, where is the bloody thing? I've seen several different suggestions and the only one I haven't tried is ripping out the passenger side kick panel because I wanted to be sure that's my problem before I go through the trouble.
If that's not my problem, would that mean it's the compressor and I need to replace it?
Any and all help will be greatly appreciated. Hopefully my post isn't too confusing. Feel free to contact me directly if you want.
Old Jun 18, 2019 | 09:12 AM
MiniToBe's Avatar
MiniToBe
The first thing I would do is actually see if there is enough pressure in the system. The compressor won't kick until the freon is at specific pressure. Give that a try first before digging things up.
Also check this site for reference newtis.info
Old Jun 18, 2019 | 10:34 AM
evelluser's Avatar
evelluser
The shop that did the diagnosis said they pressure was correct as well. I thought I had included that with my original post. But I will take a look at the recommended site. Thanks
Old Jun 18, 2019 | 10:54 AM
MiniToBe's Avatar
MiniToBe
Usually the pressure is high until the compressor kicks in then it drops to proper level.
For example, if the pressure were 180psi and the sensor is looking for 200psi, the compressor is not going to actuate. So, try to add a little more freon to see if it triggers the sensor. Walmart has these cans for $4.88. The hose is also reuseabel and sold separately.
Old Jun 28, 2019 | 08:47 AM
2014 MC's Avatar
2014 MC
How about finding the pressure switch and then jumping it (to take it out of the loop) just to test. If the clutch kicks on then most likely the pressure is just too low. This is fairly easy to check/test, but don't run it for long if it does kick in as it is a safety switch for too low pressures.
wsalopek
Dec 12, 2017 10:56 AM
Cassy
Classic Mini Talk
Nov 7, 2006 06:55 PM
ProfessorDave
Apr 14, 2006 09:42 AM
