R60 Has anyone replaced the mini fog light bulb for a LED
Old Apr 23, 2015 | 07:40 AM
Flyer53's Avatar
Flyer53
Has anyone replaced the mini light bulbs for LED's. I believe the current bulb is a 12v 55W H3....Looking for a better sight as well as look to go with the mini driving lights...Thanks!
Old Apr 23, 2015 | 10:57 AM
siriuszero's Avatar
siriuszero
I've seen H3 LED bulb replacements, but in my experience none of them have come remotely close to the incandescent's light output and range. They'll have the look, but are not really functional. A simple bulb replacement just won't cut it if you're looking to still use them.
If you're looking to go LED though, the new LED driving lights are coming soon and will be retrofittable to those who already have driving lights.
Old Apr 23, 2015 | 11:32 AM
Flyer53's Avatar
Flyer53
I have converted the lower mini fogs over to the newer DRL and they look great.
Yes I was looking to go brighten as well as making the look, look similar to the LED DRL and Xenons. I had the mini fog lamps dismounted as I was re-doing some work on the grill....thought while i had them apart I'd see what's out there for LED's. I appreciate your time
Old Apr 23, 2015 | 11:54 AM
The X Men's Avatar
The X Men
The factory LED fog lights are pretty bright, as bright as any H3 incandescent bulb I would say and it match xenon lights nicely.
Old Apr 23, 2015 | 12:18 PM
Flyer53's Avatar
Flyer53
I hope I'm not confusing the different type of lights...The lights I'm referring to are the ones pictured in my first post. Bought separately through Mini and mounted on brackets attached through the grill... The daytime driving lights i've converted over to the newer Mini style LED's and look great.
This is the bulb that comes standard in the light and am looking to change the pair over to LED's if possible. Wondering if anyone has and if so...style & size ?
Old Apr 23, 2015 | 01:18 PM
siriuszero's Avatar
siriuszero
Yes, the factory LED lights are plenty bright, but the LEDs in those are integrated into an assembly and have their own heat sink and such surrounding it.
I meant to say that a straight bulb swap, while possible, would lead to disappointing results, especially when comparing them to a factory LED light.
I found these on eBay that would be cheap enough to try, I have similar ones as reverse lights, but they will not match the light output of the factory LED or incandescent lights.
http://www.ebay.com/itm/H3-80W-CREE-Super-Bright-LED-White-Fog-Tail-Turn-DRL-Head-Car-Light-Lamp-Bulb-/261674149472?hash=item3cecfea660&vxp=mtr
Try them out - $20 for two isn't too bad of a hit and if you need something brighter, get the MINI factory LED driving lights when they come out.
Old Apr 24, 2015 | 10:13 AM
The X Men's Avatar
The X Men
Attachment 109494
The aftermarket H3 LED bulb will not be as bright as the halogen or the oem LED foglights. It might also trigger a bulb out warning as well unless you use resisters or error free bulb.
Old Apr 27, 2015 | 08:45 AM
Flyer53's Avatar
Flyer53
I've decided to replace the complete light package over to the LED's...
placed the order with ECS Tuning....should see them later this week.
Appreciate eveyone's imput
Old Apr 27, 2015 | 10:13 AM
Thanks they are right here for the LED version>
If you already have the factory rally lights in halogen , its a direct swap for R56-R61.
LED Driving Lights Retrofit Kit - Black Housing 63122288982
http://www.ecstuning.com/Search/SiteSearch/63122288982/
OR
LED Driving Lights Retrofit Kit - Chrome Housing 63122288981
http://www.ecstuning.com/Search/SiteSearch/63122288981/
For the old halogen bulbs: They take H3 Bulbs, We have Ziza options also in color bulbs. But no LED.
http://www.ecstuning.com/Mini-2011-Cooper_Countryman-R60-S_ALL4-Hatchback-L4_1.6L_N18B16A/Lighting/Rally_Lights/Bulbs/
Old Apr 27, 2015 | 10:38 AM
Flyer53's Avatar
Flyer53
OR
I ordered the LED version in black rally lights...I'm hoping to just be able to swap out the light housings... I already have the grill with brackets and the interior panel with switch.
I'm thinking these housings with the LED's will be a brighter/better look than just purchasing the super bright halogens ? ?
Old Apr 27, 2015 | 11:07 AM
Yea, the new LED rally lights are super bright ( bighter then most halogen i have seen) and they swap for the halogen housing factory one.
Spiney installed them ( as well as the factory DRL fogs ) lower lights. Install a couple pages back.
https://www.northamericanmotoring.co...changes-7.html
Old Apr 27, 2015 | 11:17 AM
Flyer53's Avatar
Flyer53
Those look Great !
I'm super excited....waiting for shipping confirmation.
Thanks for all your help
Old Apr 27, 2015 | 11:53 AM
siriuszero's Avatar
siriuszero
The LED driving lights look much better when you have Xenons/LED headlights!
How's the light output?
Old Apr 27, 2015 | 12:26 PM
Flyer53's Avatar
Flyer53
I have a 2011 R60..so have the adaptive Xenons...but have upgraded the lower fogs for the newer Mini DRL led's which look great as well.
Is there an upgrade for the headlights over to led's without swapping the whole housing ? I've actually looked into that as I like the newer blacked out look...but if memory serves me right...$800 and change per light plus the install...I'm almost at the point of no return anyways...
Old Apr 28, 2015 | 05:30 AM
No factory Led upgrade for the Factory Countryman Xenon Headlights yet.
Old Apr 28, 2015 | 05:32 AM
Flyer53's Avatar
Flyer53
Ok..I appreciate the info.. Anxiously waiting
Old Apr 29, 2015 | 07:12 AM
Welcome.
Old Jun 1, 2015 | 05:52 AM
Rai1gun's Avatar
Rai1gun
What grille / bracket do I need (2013 Countryman S) to mount the new LED rallys? I can't seem to find the right part at ECS....
Old Jun 1, 2015 | 06:00 AM
Flyer53's Avatar
Flyer53
I believe this is it....Taken from there web site..
Brand:Genuine Mini - ES#: 2543454 Mfg#: 63132241489
Old Jun 1, 2015 | 06:25 AM
Rai1gun's Avatar
Rai1gun
Is there no way to get just the bracket? Or is replacing the grille required?
Old Jun 1, 2015 | 06:56 AM
Flyer53's Avatar
Flyer53
Far as I know it comes as a kit...I eventually used another grill and just cut out openings for the brackets...but I used the brackets that came with the kit.
Old Jun 1, 2015 | 07:22 AM
Yes, you have to get the grille / brackets combo.
Old Jun 4, 2015 | 05:32 AM
dpike's Avatar
dpike
are those light covers independently available? i'd like to put a set on my halogens.
Old Jun 4, 2015 | 05:35 AM
The new ones " X " version that come with the new LED kits ? No , not yet.
Just the light covers that come standard on the halogen.
Old Jun 4, 2015 | 05:42 AM
dpike's Avatar
dpike
i'll keep an eye out for their availability.
thanks for answering so fast.
