R60 Has anyone replaced the mini fog light bulb for a LED
I swapped out the halogens for the new LED's and somewhat liked the oder style black mini covers and they did not snap on the led's securely as the newer compatible X style covers. They are a different fit/style...minimal but enough to make the difference with the covers.
You are welcome.
Someone will double side tape stick those ones
to get them to fit , thanks for testing those Flyer53
I did not see clear answer to retrofit question above. Do I have to pull all of the wiring for my current driving lights back to a point or can you just pop the new lights on the old brackets and you are set.
After all of my fun doing my LED DRL's I will probably head to shop if I have to pull the harness.
If you look at the harnesses they look the same , i would pop the new LED lights housing themselves in and see if they light right up when you have the Halogen harness. Worth a shot.
Thanks, will be my next add. I leave mine covered this time of year and then uncover when we get to that time of year when it is dark driving to and from work. Masking out and plastidiping the white red on the cover will be fun also.
We have allot of deer and the xenons are pretty worthless for the since they are so focused down the road. The driving lights catch the eyes of the ones grazing along the road much better.
Just and update 63122288982 LED version is back in stock.
Dec 23, 2015 10:36 AM
Aug 7, 2015 05:55 AM
