R60 Countryman Timing Chain Replaced
I just bought a 2012 Countryman S that I had to replace the timing chain and guides. I finished the job, cleared all codes and I ran the car for 1 minute.
The engine was surging between 1000 and 1500 rpms. it stalled after about 1 minute. These were some of the same codes I was getting before I changed the chain, guides and tensioner.
When I took the tensioner out, it fell apart in my hand. The guides were broken. I found about a dozen pieces in the oil pump and pan.
I replaced the crank and camshaft bolts.
When I finished, I turned the engine over twice and checked the timing marks and the flywheel position and they were all perfect.
I scanned the car and got these codes...
P1338 - Camshaft Position Sensor Bank 1 Open Circuit Or Short To Positive
P0300 - Random/Multiple Misfires
P0301 - Misfire Cyl 1
P0303 - Misfire Cyl 3
P1339 - Crankshaft Position/Engine Speed Sensor Cross Connected
I was told if the chain is off, there is a communication issue between the crankshaft and camshaft. Does the computer have to be reset for this to go away? I saw in a video the guy 'Reset The Adaptive Variable Camshaft Timing Control'.
Any help would be great.
Ian
Ian
I screwed up. I had a ratchet on the crank pulley to help line it up while I was underneath trying to get the flywheel pin in. I finished the job, went to start it and heard a clunk.
I had forgotten to take the ratchet off the crank and when the motor rotated, it loosened the crank bolt causing the valves to hit and bend. Compression in the cylinders are, 50, 50 150, 65.
I'll pull the head and see what other damage there is.
Do I have to get new crank and cam bolts again?
Ian
Ian
Man that's heartbreaking!
The cam and crank bolts are stretch bolts, so for sure you will want to replace them. They aren't very expensive though, even from the dealer.
Sad to say that will be the least of your costs it sounds like. It would be interesting to get one of those cheap endoscopes and see what your pistons/valves look like. Hopefully it's just the valves and the pistons/cylinders are ok.
Dan
Dan
Vanos system
Ian
Ian
HIMIKI Intake Exhaust Engine Camshaft Position Valve Timing Variable VVT VANOS Solenoid Compatible with Select 2008-2018 mini Cooper Cooper Countryman Cooper Pacema https://a.co/d/cM40842
mellowmini
02-03-2015 02:40 PM
Drivetrain Hesitation/Lazy revving. Timing off?
SniperDetailing
05-20-2013 12:45 PM
