R60 :: Countryman Talk (2010-2015) R60 Cooper and Cooper S hatchback discussion NOT REPAIR RELATED Discussions.
Sponsored by: DashLynx
R60 Stuck driver side cv axle.
Old 11-03-2018, 08:09 PM
cudamank's Avatar
cudamank
cudamank is offline
Hi,
trying to change axles on my countryman. 120k . I was able to get the passenger side out by unbolting carrier support. Was surprised it came out dry. The driver side is stuck. Cant get two prybars on it. Took the shaft apart so I am only dealing with the end . suggestions?
Should there have been fluid on passenger side?
Thanks.
Old 11-04-2018, 04:30 AM
MiniToBe's Avatar
MiniToBe
MiniToBe is offline
They are usually sealed.
I used a ball joint fork separater and tapped on it while rotating the axle. It eventually came out. It needs patience and sime time.
Old 11-06-2018, 09:42 AM
tominizer's Avatar
tominizer
tominizer is offline
If you're talking about the front drive shafts from the diff to the wheels, my driver's side would not come out. Luckily it was still under warrantee. Otherwise the bill to me would have been huge as the tranny had to come out.
That expansion clip design is absolute garbage. Just pops out my azz.
Old 11-10-2018, 04:34 PM
cudamank's Avatar
cudamank
cudamank is offline
Finally got it out
Finally got it out with a homemade slide hammer.
that was good news. New axles from import direct purchase through O'Reilly were two short . part numbers bm 8061 and bm 8060. Driver side about 2".
They are ordering another pair in. Sucks car
down 2 weeks now. I didnt see any available on pelican parts. If these ones coming don't work, where else besides dealer? (3 hours away).
Old 11-15-2018, 06:15 AM
iwashmycar's Avatar
iwashmycar
iwashmycar is offline
Any resolution? I was just about to order that 8060 for mine, but not if I am going to have the same issue!. Is yours an All4?
Old 11-15-2018, 09:50 AM
cudamank's Avatar
cudamank
cudamank is offline
The 8060 was about 2"s to short for mine.
Old 11-16-2018, 09:05 AM
iwashmycar's Avatar
iwashmycar
Near impossible to get out. I tried a rented slide hammer as well after taking off the old half of the axle...I think it was just too short. Gave up about 11pm. No amount of prying with the car only on jack stands will do it.
Just bolted it all back together with the cup still in the trans and carefully drove it to a nearby shop this morning. It wasnt too happy to drive without one CV, but was ok staying at about 25mph max. Guess we'll see how it turns out once I get the call.
Good news is the used axle I picked up is the same length as the old so they can stick that one in there. Its something like 25.X" vs. the 23 1/4" all the parts show, as noted earlier in this thread. Makes sense seeing as the CM is wider than a normal Mini.
Seeing how cuda has a 2WD base and I have a All4S, it appears (automatic trans-wise) they take the same CV shafts....but not the same CV shafts as any other Coopers as all the websites seem to say.
Happy to hear otherwise!?
Old 11-16-2018, 12:17 PM
PAWS's Avatar
PAWS
PAWS is offline
I suggest just to get GKN axles, I have them on my 2005 r53 jcw that is frequently tracked, no problems x 20k miles fcpeuro is a good vendor
https://www.fcpeuro.com/products/bmw...yABEgISofD_BwE
Old 11-16-2018, 12:20 PM
PAWS's Avatar
PAWS
PAWS is offline
oops above info is incorrect OEM Bimmer parts --- https://www.oembimmerparts.com/Mini-...1607574852.htm
Old 11-16-2018, 02:43 PM
iwashmycar's Avatar
iwashmycar
I'm fvcked anyway. Shop couldnt get the thing out. Transmission shop is probably going to have to drop the trans to even try. Im at a loss here.
I dunno, I can call the dealer, but they are never helpful. There is always that "Service Advisor" wall between us and the techs.
edit : I took it home and filled the old cv with new grease and plopped it back in to the tulip still stuck in the trans. Zip tied the bish back on and it’s running fine now. For how long, who knows.UPDATE - since I never updated it. Zip tie didnt last long. Took it to a much better local Indy shop and they got it out for me. Put in the junkyard one.I was still getting vibes and noise and decided to check the other side...Yep. dry as a bone. Was the passenger side all along I bet. I ended up slapping new grease and clamps on both and reinstalled. Been a few thousand miles now and aside from some annoying vibrations now and then its driving fine. At least I know I can get the DS one out if need be (but that appears to be a dealer only part). I didnt take the passenger side one out but I think it can be replaced with that part-store version readily available....just not sure if I can get IT OUT...I "rebuilt" mine with the side still stuck in the trans :/
Last edited by iwashmycar; 10-07-2019 at 02:16 PM. Reason: forgot to update the story
Old 10-01-2019, 09:41 PM
Kieran McMullen's Avatar
Kieran McMullen
Kieran McMullen is offline
be 8060. from orients.
i went through installing these on my 2012 countryman. they were ordered by VIN. and i swore they were 2” short or 1 1/2”. now this topic proves it. but my wife’s car down two weeks down also. why they still sell them?if anyone knows of a brand that fits? any help please email me thanks
Old 10-07-2019, 02:11 PM
iwashmycar's Avatar
iwashmycar
Pretty much certain OEM is the only option... I suggest just buying grease and clamps....They sell packets of grease and clamps at Napa. Open up, squirt the packet in, and reclamp. Done. Easy to 'rebuild'. I did that to both of ours and they have been pretty much fine since....some vibration here and there, but what can I do!
HowardH
01-13-2019 07:44 AM
wojtek@pagacz.ca
08-27-2018 12:16 PM
gpwpat
09-18-2016 02:48 PM
idickers
12-22-2011 04:03 AM
meb
Suspension
07-18-2007 08:11 PM
Quick Reply: R60 Stuck driver side cv axle.
