R60 Rear Mount Bike Rack - 2 significant problems
I bought the Rear Mount Bike Rack for my MINI CM.
Problem 1 FAIL: Yes, the rack releases and slides forward for access to the rear hatch as advertised - but when my 29'r was on the rack, the hatch could not clear the handlebars; therefore, it could not be opened.
Problem 2 FAIL: The rack is not designed to handle two bikes -- at least not the two I wanted to haul. In my photo, it looks like the two bikes are installed. But the 2nd one was removed immediately after I took the photo because it had an interference fit not only at both wheels, but also at the seat of the inside bike and the handlebars of the outside bike.
There was no way to configure the location of these two bikes to get them to fit without interference.
So for me, this is a very expensive one bike rack --- which prevents the hatch from being opened when the bike is on the rack :-(((
Dude, I feel your pain. I also have 29ers (Niner Bikes as well - RIP and Jet) in size large and before I placed my order for a CM I made sure there was a way to attach my Thule T2 rack, because that's the only way I carry those bikes.
If they won't take it back maybe you can sell it and go the MiniFini hitch route with the Thule, or carry them on top.
I have the rack and have the same issues. I can get my hatch open but I have to pull my handle bar out ofthe way to do it. The big problem for me is when I load my bike (29er) and my kid's bike my frame rubs agains my kids front forks and it has put marks in the paint on my frame. One of the many things I have grown to not llike about the car.
We've run into some issues on ours as well, but more with just getting the bikes to load properly.
2 design changes that can easily make this rack better:
1. Inner rail mounts need to be able to go closer together. In our case, and in the OP's photo, the inner bike doesn't sit fully in the tray due to the wheelbase being smaller than the minimal distance the rack will hold.
2. Rails need to be wider. This, coupled with fix one, will allow you to offset the bikes a bit avoiding frame / fork / skewer / pedal contact between the bikes. Will also allow for larger wheelbase bikes (which as 29r's) to fit.
I really want this rack to work. We don't have 29'rs (yet) but I fully expect to have one next year. Our CX bikes fit, which is the biggest concern we have.
I'm wondering if the minifini CM design is easy to install and comes with the trailer hitch. We had the trailer hitch for our 2007 CooperS which we coupled with a Saris Thelma rack. I'd love to be able to re-use the Thelma as it is a great rack.
Don't use rear mount bike racks. (A), they are just a hassle when it comes to stuff like this - opening hatches and strapping them up and protecting both bikes from each other, and, maybe more important, (B) they really really screw up the handling of the car, especially such a small car. You're hanging over a hundred pounds way behind the rear bumper, effectively adding all of this unsprung weight off the rear axis, where it shouldn't be. I did this once with a Subaru Outback, and hated the handling, so i can't imagine what it would do to a Mini.
Go for a top rack, fork mounts, with wheel holders. Be careful if you have a sunroof - make sure the rack gives you enough clearance. That's my setup, using Thule. Oh, and be really really conscious of low hanging garage doors.
I disagree. I like rear mount racks because I don't have to remove the wheels to get the bike on. As much biking as I do, this alone is worth it because it saves a lot of time. The Thule T2 is the fastest loading/unloading rack there is (we're talking 10 sec here) and the bikes don't touch each other. If I am carrying one bike or have the extra two bike attachment for carrying up to 4 bikes, I can put the bike in a position further away from the tailgate and still be able to open the tailgate enough to get stuff in/out.
I don't notice the change in handling that much unless I have 4 bikes on the back, and I am not going to be driving aggressively with bikes on the car anyway.
Most folks I know at some point have had temporary memory lapses and forgotten their bikes on top and run them into something. In addition, you run the risk of scratching your paint or damaging the sunroof. It's not worth it.
Gas mileage is way worse with bikes on the roof than in the back.
Once somebody really nailed my car from behind, but my rack and hitch took the brunt of the impact, saving thousands of $$ damage to my car and completely disabling his (no drive-offs). However, I was lucky as no bikes were on the back, so you could look at this either way.
Just my opinion.
Just my opinion.
Once heard a comment:
"There are two types of people with roof racks. Those who have driven into the garage with the bike on top, and those who have yet to do so."
Pretty much nails it from my observations.
I'm still very curious about the MiniFini CM attachment. Anyone picked one of these up?
stiksandstones (01-15-2022)
And, as far as the "vertically challenged" thing, uh, holy jeebus, we're talking about a Mini here, right?
Has anyone had any success with a Thule rear hitch? I'm looking at the 9003 Raceway Platform 2 to be used strictly with two classic road bikes.
By the way, does the Countryman have a rear hitch or can one be ordered?
Thanks!
Thanks!
Thanks!
Thanks!
Currently, the only Countryman box hitch receivers are third-party aftermarket -- two require cutting a hole in your rear bumper and cost ~$300:
MINIFINI Country-Link
Mini Do More Model 1006
A "no drill, no cut" receiver from CabooseTrailers attaches to the rear tow hook mounts and has a disappointingly low weight rating of 150 tongue/1,000 tow while still pricing out at $250 + shipping.
Last edited by Karrock; 06-27-2011 at 07:54 AM. Reason: fixed minifini and caboose trailer links
Missing Protective Caps (2x)
Hi all,
I just purchased a new Countryman w/the Rear Bike Rack installed. So far so good in terms of usage.
I have a quick question for you all who own the rear bike rack accessory: Did your bike rack come with the "Protective Caps" that are used to cover the threads of the screw connectors? According to my dealer, Seattle MINI, the bike rack does not come with the specified Protective Caps as indicated in the instruction manual.
Can someone confirm? If you do have it, can you post a photo of the item.
The dealer indicated that the Protective Caps are only part of the European model of this bike rack. Any helpful information is appreciated!
Cheers!
Cheers!
Yes there are end caps. Mine came in the box and i opened when i got home. Your dealers has lost them.
My only issue is i can not get the rack in the back with the rear seats up. If i go for a ride and get a flat i used to get my wife to come and get me in her mini van. We have two kids so seats need to be used. Was hoping i could get it back there and fit it on the road rather than have her try and fit before she leaves.
Will have to see if she can do it.
However, you are loading the rear suspension with an additional 150 lbs (of sprung weight) and, being that the load is located about about three feet behind the rear track, this may have a slight "lever" effect. The most noticeable impact might be on the jounce and rebound of the dampers; less so if you have the sport suspension. For those with track/autocross experience, you might also feel the very slightest delay in turn-in response. The whole deal should have about the same effect as putting 150 lbs of sandbags at the hatch opening.
Like another poster offered, you probably don't want to drive with a track/autocross style with your precious bikes hanging off the rear!
Caboose hitch-
I'm looking for a bike rack option- not really interested in the mini bike rack or top rails. Anybody tried the caboose hitch? Do you then just find a Thule bike attachment to fit in? Don't know how it works- I've always had the rear mount/ temporary rack. Not an option on the Countryman....
http://www.countrymanconnection.com/...ler_Hitch.html
Their pic #14 really highlights how far the Caboose extends a bike rack out past the rear of the vehicle. O.o
And all three aftermarket hitches (MINIFINI, MiniDoMore, Caboose) use a 1-1/4" box receiver, which is an industry standard, so just make sure you buy one for 1-1/4" and not the 2" variety (unless you want to use a wobbly adapter).
I would agree that the combination of adapter and bike carrier you have shown is not good as it places too too much leverage against the adapter and will likely twist it.
However, I think the adapter is a great solution for lightweight trailers and some bike carriers. I'm getting one.
And, just wanna give a shout-out to MINI of Alexandria (technically, it's Passport MINI) for hooking me up with a MINI Rear Bike Carrier (82712149493) -- I looked up their price on PassportAutoParts.com and it rung up at $493.60 versus the retail of $617.00 and gave them a call expecting to have to place a special order.
Surprisingly, when the guy on the phone looked it up in their system, he said they had it in stock -- plus to bring in a printout of the website price and they'd honor the online discount! Saved over $100 and was in and out of the dealership in minutes -- awesome!
I don't have oversize tires on my MTB -- it's only 26" wheels, so I don't expect to run into the problems people have been having with the larger bikes. I'm test riding a road bike later tonight and may take it home, so I'll attach the rack so I won't have to fold down the seats and toss it into like cargo.
Good luck to the rest of you!
The other day, I saw a Saris Thelma rack folded up flat against the rear of a Highlander, it looked beautiful but might ride rather high on a Countryman.
Team Lope Thelma 3 Review on a Clubman
Guess you're looking for one akin to the MINI Rear Bike Carrier that's more even with the mount point like the Saris CycleOn Pro?
