Drivetrain Manic tune stage 2
Old Oct 1, 2017 | 05:19 AM
  #101
MRH74's Avatar
MRH74
JCW or hybrid turbo
Hello everyone.
I would like to have your experienced opinion!
I'm considering to put a JCW or hybrid turbo (just compressor side)
Then, i'll go for a manic tune.
My main goal is to gain better top end power.
Once i´m not considering meth by now, is best to suit lower boost? For example: Map A: 17 psi, Map B: 18 psi....
Any advice is wellcome!
Mini regards.
Old Oct 1, 2017 | 05:59 AM
  #102
cerenkov's Avatar
cerenkov
If you want more top end power then you really need a bigger turbine. The stock S and JCW run out of air at higher rpm. You will lose some low end response.
Old Oct 2, 2017 | 08:29 AM
  #103
Bnourai's Avatar
Bnourai
Originally Posted by njaremka
Black smoke from running catless. Pops and bangs are only in sport mode. Did you get the BBQ mode? What exhaust are you running?
Now i know what you saying... no but...it flames
Old Oct 2, 2017 | 08:34 AM
  #104
Bnourai's Avatar
Bnourai
so now another Question, i like to tame down the exhaust, i was thinking instead of my 3" pipe to muffler just go with 2.5" and a RES.
thoughts Please.
Old Oct 3, 2017 | 04:09 AM
  #105
MRH74's Avatar
MRH74
Originally Posted by MRH74
Hello everyone.
Mini regards.
Any advices from those that upgrade the turbo... is recomended to "work" with a little less boost?
I already have 100 cell akrap cat, full 2.5" exhaust, Bigger intercooler, colder plugs...
Thanks on advance!
Old Oct 6, 2017 | 01:22 PM
  #106
Bnourai's Avatar
Bnourai
Well went to my trusted muffler shop, installed a 2.5" pipe from down pipe with a very nice MF resenator now I like to drive the car very deep sound and still have my power...love it before it was 3" straight pipe to muffler I think it was stealing HP. I kinda feel I have a little more pep.
Ben
Old Oct 10, 2017 | 11:58 AM
  #107
MLH44's Avatar
MLH44
We have the same setup. I also added the Forge BOV Recirculating. Luv that surberine sound when it releases boost, but I've done my homework on this cause I'm shopping for a new high flow turbo and here's what it comes down to.
If you're looking for top end go with a 47mm or higher HP turbo. They'll take a little longer to spool but the dyno data says you'll have all the top end you need for tracking. The 43mm HP turbo is quick spooling and best suited for folks who want speed quickly and throughout the rpm range. I've decided to go with a JMTC 43mm. Hope this helps.
Thanks on advance!
Old Mar 31, 2018 | 04:42 PM
  #108
weaverpsu's Avatar
weaverpsu
Stage 2 question - Inspection
I'm currently in CO and we don't even have inspections. However, I'm moving to NJ in about 9 months and they are notorious for being strict. Do I have any chance passing with Stage 2? I am currently mod free and I'm trying to figure out if Stage 2 is worth the aggravation or if I should just go with Stage 1 (Intercooler, plugs, ECU) Thanks!
Old Mar 31, 2018 | 05:26 PM
  #109
Bnourai's Avatar
Bnourai
If you went with stage 2 make sure you get the sps you can hook it to your OBD and back to stock drive a few miles before inspection it will pass.
Ben
Old Mar 31, 2018 | 06:26 PM
  #110
MarioKart's Avatar
MarioKart
Vendor
send me a PM or Email MarioPalza@gmail.com. I can help you with tuning and the NJ concern.
Mario
mQubed Motorsport RPM Power and Manic Dealer
Old Apr 5, 2018 | 09:33 AM
  #111
tominizer's Avatar
tominizer
No one jumped on this one and I was wondering as well
For those of you with a catless downpipe, how have you been passing inspection? I've been told the Manic Stage 2 tune will eliminate the CEL due to the downpipe but will NOT set the OBD catalyst readiness monitor. This is crucial for me as the car will pass visual with the secondary cat but will not pass the scan here in PA for OBD readiness monitors. If this is true I'm considering throwing in the towel and going back to stock because its a pain in the butt to swap out the downpipe annually.
Thoughts ??!?!
Old Apr 6, 2018 | 09:48 AM
  #112
MarioKart's Avatar
MarioKart
Vendor
Thoughts ??!?!
send me an email with your phone number and I can talk about a solution MarioPalza@gmail.com
mQubed Motorsport, Manic and RPM Power Dealer
Old Nov 2, 2018 | 10:47 AM
  #113
Pauly Jay's Avatar
Pauly Jay
Ben
Please define how many miles? 20, 50, 80? I just had mine in the stock map and a CEL came on. Cleared it and 2 monitors are not ready. Drove probably 2 miles since then.
Old Nov 2, 2018 | 12:15 PM
  #114
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
I passed Connecticut state emissions test with Manic Stage 2 running on map B. State allows up to one "Not Ready" monitor, and my downstream O2 sensor shows "Not Ready" on all maps, except "Stock" map. "Stock" map will illuminate the CEL for downstream O2 sensor.
Old Nov 4, 2018 | 06:09 AM
  #115
Bnourai's Avatar
Bnourai
I passed my inspection about 5 -8 miles prior I switched to stock with my sps and monitored they both went green in ready state, and passed with flying colors.
thx to Mario for SPS.
ben
Old Nov 30, 2018 | 08:29 PM
  #116
MarioKart's Avatar
MarioKart
Vendor
I’m running stage 4 RPM Power Tuning with our new 400whp turbo kit
Mario
mQubed Motorsport Manic & RPM Power Tuning
Old Dec 4, 2018 | 11:41 AM
  #117
normtrum's Avatar
normtrum
Hi guys/gals. Ok so I just went through this entire thread, and I am admittedly not even close to you guys about this stuff, so I apologize for what I guess is a pretty stupid question, but why is it that all the gen 2’s are able to handle all this power, or potential power, (such as Mario’s post of that incredible 400+ HP turbo upgrade), but the gen 3’s can’t? As you can see I’ve got a ‘16 f56 JCW, and according to all the huge amounts of threads I’ve been through, there seems to be too many ancillary issues that my car simply can’t handle. I mean if you google “turbo upgrades for 2012 MCS” you get about 20 options for 400+ hp gains. What’s the deal here? Again, my apologies for such a “noob” question.
Mike
Old Jan 7, 2019 | 09:17 AM
  #118
normtrum's Avatar
normtrum
Bump on this thread, and the question I asked. Thanks!
Old Jan 7, 2019 | 11:33 AM
  #119
tominizer's Avatar
tominizer
Whoa......... that's totally exhaust **** right there?!?! I don't even want to ask what that 400whp build costs.
What stock bits are being upgraded to handle that power Mario ?
Noticed the "Made in Canada" markings. Very cool.
Old Mar 27, 2019 | 01:18 PM
  #120
weaverpsu's Avatar
weaverpsu
I've seen the NGK plugs for Stage II listed on this forum at $75 when breaking down costs of Stage II. On Amazon, they are $38. Am I missing something?
Amazon Amazon
Nevermind, I got my answer
Colt45Magnus
Aug 27, 2024 05:03 AM
cmanlu
R58 :: Coupé Talk (2012+)
Aug 25, 2015 07:35 AM
Aug 21, 2015 11:25 AM
atlas8000
Aug 14, 2015 07:45 AM
