R58 water in passengers side, engine cranks but does not start
Old Mar 9, 2020 | 09:43 AM
E34M5's Avatar
E34M5
water got into passengers side of vehicle through roof/window, now engine cranks but will not start, any ideas? possible footwell module? Thanks in advanced
Old Mar 12, 2020 | 05:14 PM
gresh's Avatar
gresh
Yep. The bottom wire harnesses get wet and short out the relay on the module. Not too expensive to fix. Junk yArd or eBay for the part used.
Old Mar 13, 2020 | 06:29 AM
MiniToBe's Avatar
MiniToBe
+1
it is called fuse box or JBE. the footwell module aka FRM is on the left side (drive). you could buy a used one with same part number OR of the same model car if you cannot find same part number box. it is recommended to code it so you may restore the functions specific toy you car.
lastly, try to clean the connectors and use dielectric grease.
Old Mar 19, 2020 | 06:02 AM
Footwell module i bet. you can try to clean it like above and see if it works otherwise you will need a new one. Some have been covered under warrenty extension, but that is per VIN and with no physical damage.
https://www.northamericanmotoring.co...solutions.html
If i find the thread one person fixed the rusted wire and connections an it worked.
LiftedR60
R60/R61 Stock Problems/Issues
Mar 10, 2020 06:00 AM
Blown-Lone-Star
Feb 15, 2011 07:26 PM
user 7082082
Dec 27, 2007 04:18 PM
Mr._Bridger
PittStop MINI Club
Aug 1, 2004 05:16 PM
